Hokay,
lend my your ears eyes,
New car is down on compression on the number 5 jam pot, but I don't know why!?!?!?! it came up at 88psi when the rest were 150-160
The car has dodgy valve stem seals, so blows some smoke after idling for a while, but that is unrelated to the lack of compression. (or is it?)
I initially thought the rings were shot, but it doesn't blow smoke under load and the motor is very quiet, has very minimal blow-by and feels quite strong and smooth, idles smoothly yadda yadda yadda.
It is a dead stock 1JZ with a cat back, standard boost factory intercooler etc.
Now to my theory, is it at all possible that the leaky stem seals have gummed up the back of a valve which is causing it not to close/seal properly? I'm sure it is possible, but I have never seen/heard of it in person.
Now when my RB25 chewed up and spat out a ring, the smoke would increase with revs/load as well as showing obvious pulsing blow-by.
I'm going to try and borrow another comp tester and squirt some oil in the bore to double check (I didn't have anything handy this morning)
But like I said, no smoke under load, to me it doesnt make sense.
So I hope you can help too a) put my mind at ease and b) save me from having to buy a new motor
Cheers
A
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/
  • Replies 52
Posted Images
So, easiest way would be pressurize the cylinder and listen in both the intake manifold and the tail pipe for the hissing?
I would but my air compressor is at my old mans house 1100ks away lol
Titan - yeah, only smokes if its idling for a while, if you blip the throttle after idling you get a big puff of blue oily smoke.
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6139947
smoke sounds like a turbo oil seal (early). a little leaks down the dump while off, then starts to burn out once hot. it can seal up under boost depending on where it is farked so no smoke then.
nfi on the compression.
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140059
I had considered that, but it the smoke is too instant after starting cold, and I'll be f**ked if I am pulling 1J turbos off ever again! lol
I will pull the cooler piping off tomorrow and have a squiz, but 20 years of crank case gasses being sucked into the intake pipe means it will be oily
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140068
i was goin to say just before mine let go it would blow blue smoke on start up and miss a bit...then as it got warmer the smoke would disappear and the miss would go away as the rings sealed better
if urs isnt missing at start up then its not the same case as mine...
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140355
Valve stem seals would explain the smoke / burning oil on start up,
the burning oil may have glazed the bores and your leaking compression past the compression rings, preventing a proper seal with the glazed bores, but your oil control rings are still sealing to explain why your not consistently burning oil
leak down test / wet comp test will help
May also be leaking passed the head gasket giving you low comp
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140375
There is no use over-complicating the issue. It's practically a dead stock 1JZ....the likelihood of glazed bores is so remote, it is literally the last thing you would consider. That and the fact it would smoke all the time if that were the case.
You definitely need to do a leakdown test before you can make any assumptions. It could even be a worn valve guide causing the valve to seat incorrectly AND make the stem seals leak - also not likely on a single cylinder
Remember when you are doing the test to have it at TDC Comp on that cylinder
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140650
So the plot thickens.....
These are the same plugs that were a little oily the other day...cleaned them up and put them back in.
Pulled them out again today...
:unsure: looks a lot like rust to me
compare these to one from the Soarer
The orange plugs are BRK6EP's
cyl 1 on the left and 6 on the right
the plug from the soarer is a BKR6E
found my little high power torch so had a look down the plug holes, piston crowns are dry, and also have a slight brown/orange tinge, No sign of any oil in #5, they all match evenly.
So I am thinking that Duncan is correct in saying that it is a turbo seal, Causing my smokey exhaust
Doesnt explain the lack of comp in #5, but I may have muffed the test, there was a bit of crap around the #5 plug hole that may have caused the tester to leak >_<
The car doesnt seem to use any water, but I havent owned it long enough to say for sure, the oil is about 400ks old and looks brand new, so I think that if it was rings the oil would be a lot darker
Any more ideas
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6144324
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
