Hokay,
lend my your ears eyes,
New car is down on compression on the number 5 jam pot, but I don't know why!?!?!?! it came up at 88psi when the rest were 150-160
The car has dodgy valve stem seals, so blows some smoke after idling for a while, but that is unrelated to the lack of compression. (or is it?)
I initially thought the rings were shot, but it doesn't blow smoke under load and the motor is very quiet, has very minimal blow-by and feels quite strong and smooth, idles smoothly yadda yadda yadda.
It is a dead stock 1JZ with a cat back, standard boost factory intercooler etc.
Now to my theory, is it at all possible that the leaky stem seals have gummed up the back of a valve which is causing it not to close/seal properly? I'm sure it is possible, but I have never seen/heard of it in person.
Now when my RB25 chewed up and spat out a ring, the smoke would increase with revs/load as well as showing obvious pulsing blow-by.
I'm going to try and borrow another comp tester and squirt some oil in the bore to double check (I didn't have anything handy this morning)
But like I said, no smoke under load, to me it doesnt make sense.
So I hope you can help too a) put my mind at ease and b) save me from having to buy a new motor
Cheers
A
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/
  • Replies 52
Posted Images
So, easiest way would be pressurize the cylinder and listen in both the intake manifold and the tail pipe for the hissing?
I would but my air compressor is at my old mans house 1100ks away lol
Titan - yeah, only smokes if its idling for a while, if you blip the throttle after idling you get a big puff of blue oily smoke.
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6139947
smoke sounds like a turbo oil seal (early). a little leaks down the dump while off, then starts to burn out once hot. it can seal up under boost depending on where it is farked so no smoke then.
nfi on the compression.
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140059
I had considered that, but it the smoke is too instant after starting cold, and I'll be f**ked if I am pulling 1J turbos off ever again! lol
I will pull the cooler piping off tomorrow and have a squiz, but 20 years of crank case gasses being sucked into the intake pipe means it will be oily
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140068
i was goin to say just before mine let go it would blow blue smoke on start up and miss a bit...then as it got warmer the smoke would disappear and the miss would go away as the rings sealed better
if urs isnt missing at start up then its not the same case as mine...
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140355
Valve stem seals would explain the smoke / burning oil on start up,
the burning oil may have glazed the bores and your leaking compression past the compression rings, preventing a proper seal with the glazed bores, but your oil control rings are still sealing to explain why your not consistently burning oil
leak down test / wet comp test will help
May also be leaking passed the head gasket giving you low comp
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140375
There is no use over-complicating the issue. It's practically a dead stock 1JZ....the likelihood of glazed bores is so remote, it is literally the last thing you would consider. That and the fact it would smoke all the time if that were the case.
You definitely need to do a leakdown test before you can make any assumptions. It could even be a worn valve guide causing the valve to seat incorrectly AND make the stem seals leak - also not likely on a single cylinder
Remember when you are doing the test to have it at TDC Comp on that cylinder
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6140650
So the plot thickens.....
These are the same plugs that were a little oily the other day...cleaned them up and put them back in.
Pulled them out again today...
:unsure: looks a lot like rust to me
compare these to one from the Soarer
The orange plugs are BRK6EP's
cyl 1 on the left and 6 on the right
the plug from the soarer is a BKR6E
found my little high power torch so had a look down the plug holes, piston crowns are dry, and also have a slight brown/orange tinge, No sign of any oil in #5, they all match evenly.
So I am thinking that Duncan is correct in saying that it is a turbo seal, Causing my smokey exhaust
Doesnt explain the lack of comp in #5, but I may have muffed the test, there was a bit of crap around the #5 plug hole that may have caused the tester to leak >_<
The car doesnt seem to use any water, but I havent owned it long enough to say for sure, the oil is about 400ks old and looks brand new, so I think that if it was rings the oil would be a lot darker
Any more ideas
https://www.sau.com.au/forums/topic/384934-ok-im-stumped/#findComment-6144324
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
