  • Replies 52
Posted Images
My money is on that the rings aren't broken, but the ring land for the top ring has failed. Listening for where you can hear compressed air escaping from most when doing the leak down test will give you more clues. Sump, head, intake exhaust. If you hear anything in the intake or exhaust, its valves/seats. You shouldnt hear anything (or very little). If its either of the other two, combined with a bad result and its a head off/engine out deal looking for bad valves and seats, or a broken piston/rings.
Stem seal leaks will only have an effect on the cylinder when a valve is open, and have no effect at all on cylinder compression.
This is why I'm confused, you would think that a broken ring land would show up with oil on the plug and piston crown, as well as it blowing smoke under load.
It has none, it is also very quiet as I said before.
If I wasnt so poor due to it being the silly season I would've pulled the engine already, but alas I am broke, hence this thread lol
The lack of oil in the chamber tells me if it is guides/seals, than it is the exhaust side
I agree with you, but look at the JZ piston designs. They run a massive crown thickness above the top ring. If the 2nd ring and oil rings are intact then you won't get oil above the piston crown and in the combustion chamber.
old rule - If it smokes after idling its valve related, if it smokes when you accelerate its rings. You say it smokes at idle and then you rev it. This means valves, guides etc. But on a turbo car you have to add the turbo seal.
Did u try a wet test?
I bet the last owner used octane booster when he was running 2 bar the day before he sold it to u .... Well hopefully not. But he must have used booster for the plugs to look like that
  • 4 months later...
ok back from the dead thread is no longer dead
Car died on me a couple of days ago, made a nice bang and stalled, but managed to get it going again so NFI what it was.
But just got back in from playing with it, popped the breather hose off and blocked the PCV...and Holy Shit cakes Batman, there be some blowby about lol
Has a nice chuff to it, so 1 or 2 clyinders are stuffed.
No idea why I'm updating this, but someone may care lol
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
