Note:
- Located northside Brisbane
- Not posting one $5/$10 item but will post multiple ones or more expensive items.
- Contact via pm or 0401 669 900
1. Pair of S13 mirrors $80
2. rear reo bar $30
3. rear number plate lights $20
4. Passenger door including window mechanicals, handle etc straight with pinstripe deleted no glass $80
5. Driver's door including window mechanicals, handle, dented no glass $50
6. Silvia rear taillight garnish (between lights and rear bar) $50
7. Blits 180sx passenger’s vented wide guard GC $50 (no drivers guard)
8. S13 cat back exhaust with twin pipes. Looks like a 5 year old did the welds $20
9. S13 thermostat housing rear $20
10. SR20 auto gearbox mount $10
11. 180sx headlight timer relay and loom $20
12. SR20 injector rail $20
13. SR20 cam gear single $10
14. SR20 cam gears $20 (inlet and exhaust)
15. SR20 Motor brackets for alternator, power steering $20 each
16. Analogue climate control $10
17. Inlet manifold support bracket $15
18. Water pump pulley x2 $5ea
19. Raizin volt stabilizer $40
20. Accelerator pedal x 3 $10 each
21. Fuse box covers x 2 $10 each
22. s13 wiper stalk $20
23. S13 fuel flap $10 some surface rust, otherise good
24. Custom RB25/26 into S13 gearbox crossmember $40
25. Wiper motor $30
26. Bonnet pop latch $20
27. Firewall plastic covers (sits in front of windscreen) $20
28. Wiper motor arms (behind firewall) $30
29. Metal cover that sits over the bottom of the front windscreen $20
30. Centre console surround in black $30 paint average
31. Omori oil temp guage faulty $20
32. SR20 stainless manifold (pin hole in the collector welds) $50
33. Aftermarket steering wheel $40
34. Key hole plastic surround $5
35. S13 front seatbelts (pair) $50
36. Various interior plastics $10 each, too many to list, buy multiples cheaper
37. Bonnet rod/support $20
38. 180sx rear centre garnish, chip in corner $10
39. rear ¼ window rubbers (2 sets) $40 pair
40. Power mirrors controller fits in centre console $20
41. S13/180sx scuff plastics in door sil $30 pair
42. SR20 flex plate (between gearbox and engine) $40
43. Pod filter adaptor $10
44. Plastic trims between the door and ¼ window $40 pair
45. O2 sensor smaller thread $20
46. SR20DE cams and cam gears, will need a tidy up on the lobes $80 pair
47. HKS green mushroom filter $40
48. SR20DET AFM $50
49. SR20 thermostat housing complete $40
50. S13 rear brake lines $40
51. Various turbo oil/water lines $5 each
52. Stainless 2.5” pipe for mounting a Greddy BOV $20
53. Momo horn button $20
54. GFB bleed valve $40
55. SR20DET coil pack looms x 2 $40 each
56. Silicone joiners $10 each 2”, 1.5”
57. R33 castor rod brackets
58. R33 uprights and 5 stud front hubs $50 pair
59. R33 upper camber arm front $30 pair
60. R33 Rear traction arm $30 pair
61. R33 Rear camber arm $30 pair
62. R33 front castor rods $60 pair
63. R33 factory suspension $80
64. R33 power steering rack $100
65. R33 front swaybar $30
66. R33/RB25 engine crossmember $50
Parts I need and will swap parts for:
S13 carpet
S13 dash
S13 cluster
S13 centre console
S13 silvia front headlights
180sx boot plastics
180sx rear arch plastics
SR20 aftermarket radiator
Edited by Mase
https://www.sau.com.au/forums/topic/384940-over-60-s13-and-r33-parts/
  • 1 month later...
  • 4 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
