hey guys
i recently got 3 drift irduim gauges isntalled, they are water temp, air fuel, and oil press
the car doesnt feel the same as b3fore the gauges were installed, power wise its the same, however
when i take off, it feels like it will stall a lot more easier than b4, i need to giv it a bit more gas than b4, also the car used to back fire and sound better, where as now its a lil more quiet, and now the car struggles to get
up my drive way, where as b4 it would drive up, hence i need to give it more gas.
also have a slightly idleing problems that happens every now n then, this only happened after the guages were installed, car goes up n down betwen 1-2g
also i believe the water temp guage isnt working properly s when i start the car at 6am, its reading at 80 degrees?
oil press seems fine however it fluctuates a fair bit,
i rekont theres a chance the air fuel gauges is p;aying up
any ideas guys?
https://www.sau.com.au/forums/topic/384942-new-drift-gauges-stuffed-up-my-car/
Dude, when you were installed senders for your gauges, did you take something apart? E.g. intake piping? Sounds like good old vacuum/boost leak to me. You may have forgotten to put back some small hoses or forgotten to tighten some of intake hose clamps.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
