Just after peoples opinions on this.
I was out driving yesterday and about 1/2 hour into the trip I tried to acellerate up a hill and noticed I had bugger all power.
It feels like I have 1/3 or less the power that I normally have, it takes over 5 seconds to acellerate from 90 to 100 :blink:
I didnt hear or feel anything happen, the motor still runs and idles smoothly but has bugger all power.
The boost guages (factory and eBoost) both show vaccume but neither will rise above zero when under load.
When the load / revs is in the area where it would normally produce boost it emits some white smoke. I guess this is cause its now running quite rich without the extra air?
So my questions are, what can I look for that may indicate what the problem is? Does a blown turbo exhibit these symptoms?
Could it be something else like the eBoost?
Some basics
- RB34 GT-T
- FMIC
- PowerFC
- eBoost
https://www.sau.com.au/forums/topic/384961-so-something-broke/
Pull the dump off and have a look at you turbine if there is one. Like mafia said check cooler piping. Don't drive it untill you find the problem if it is a blown turbo there will be bits of ceramic everywhere if some gets into the motor then hello rebuild. Also is it a rb34 strocker or did you mean r34? Guessing it's a rb25 neo. If it is the turbo then pull it all off including manifold and ensure it's all clean also drop the cat as it will be full of turbine wheel. When my turbo blew made hardly any noise if you have a loud exhaust you wont hear it.
Check list
Check for split /popped silicone hoses
Remove dump check turbo turbine wheel if gone remove turbo and manifold also cat converter
If its neither of these drop the cat it may be blocked and will cause little or no boost
These are my experiences in the past they may help otherwise I'm not sure
If there is one. had to laugh at that.
Will do that when I have some time on the weekend.
Had already had a look at the plumbing, could not see anything obvious.
Ouch.
I have already driven it over 300km (problem happend far from home).
If the impeller breaks up can it actually make its way past the the FMIC? I would have thought it would have got stuck there?
Doh!!!
Yes its a R34 with a RB25. Silly slip there.
Check list
Thanks, will run through the rest of these over the weekend.
There is a bearing case that stop it getting anywhere near the cooler haha. It can go back up the manifold and slip into the engine when the valve is opened 9 times out of 10 it won't but still that chance. Also your want to look at the rear housing of the turbo that's the turbine wheel that's the one that will go more then likely if it's not that wheel check the front but I doubt it. By memory its a 6 bolt flange on the dump 4 bolts 2 nuts I think it's a 13 mm spanner bit of a pain to undo but not impossible. Feel free to ask questions if you get stuck
What exhaust system do you have mate?
If you cant see anything wrong with the turbines, id say that a resinator has collapsed and blocked the exhaust.........or somebody doesnt like you blocked it :rolleyes:
The symptoms you just gave sound exactly like mine when mine collapsed, apparently its common with kakimoto exhausts.
Just drop the exhaust at the downpipe and drive it down the road, you will soon see if it has solved your problems :thumbsup:
Ahh that sucks mate (not as much as P-platers writing your car off though). I was running a highflow on the Neo engine in my Stagea, built by a local turbo guru but even something like a Hypergear bolt-on highflow (not one of their huge ones with custom housings) would be an excellent bang-for-buck upgrade. Should be able to get an easy 220-240rwkw out of the standard injectors, was only running 15psi through mine but it certainly made the 2t bus get up and boogy.
In the end Ive decided to send by old turbo to hypergear to be rebuilt and highflowed.
Seems to be the easiest and most cost effective option given that I dont want to change injecters, AFM, etc.
Super happy fun sideways time will shortly ensue! :devil:
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
