  • Replies 96
hey mate do u have the stock boost reader if so how much? and by boost reader i mean the little black box thats screwed to the firewall that the vacum line attatches to that makes the stock boost gauge work and do u have the r32 ash tray?
thanks
thanks
yeah got boost reader,$20 no ash tray sorry
hey mate do you still have ignition barrel and key if so how much??? and drivers side door window
yeah got key and barre $40l,do you need the door lock to match? and you want just the glass?$50 for glass
ill get you to pm ur bank details and stuff ill get those 2
did you need the door locks,or just the barrell,key and window
door locks as well would be awesome . can u give us a price sent to taree nsw 2430 very keen
also rear coilovers ???
Edited by Tommy Gee
85bucks for door locks and boot lock,barrel,key deliverd,i think it would be to hard a risky sending window,but can get a price on postage of window if realy want it,
this is most of what i have left
3inch cat back exhaust $250
front hubs,knuckles,control arms,castor arms with new bushes,upper control arm with new bushes, $150
rear cradle with hicus lock bar,$100
shimmed r32 lsd diff $200
5 bolt shafts $80
seats front and rear $100
abs unit
drivers window switch
crossmember
brake booster and master cylinder
pedals
seats
dash
dash cluster
boot interior
tail lights
door trims
rear pods
rb25 cas
shimmed r32 lsd diff $180
5 bolt shafts $80
abs unit
crossmember
pedals
seats
dash
dash cluster
boot interior
tail lights
door trims
rear pods
rb25 cas
brake booster master cylinder
clutch master cylinder
msg on 0431 540 141
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
