Hi i have a little problem... For some reason no matter what ive tried i cant get any air to come out of the middle dash vents. Its as if its on low whilst the rest are on high? Every other setting works, but when on face setting only the 2 sides work and the middle vents push out air asif its on low and u cant even feel it.
Ive looked under the steering wheel area and noticed that the hook thingy for the heater isnt on and fell off but that doesnt bother me. ive tried wiggling it around to see if it budges and no luck.
Do i need to pull the whole dash apart to get to the dash vent? or is there anything i can do if i take out the cd player area dash fascia part?
Also the car is a 1994 R33 4door.
Edited by corpse.
https://www.sau.com.au/forums/topic/385005-middle-dash-vents-no-air/
Silly but are u sure the vent is all the way. it has a halfway setting which lets out stuff all air. otherwise you should only have to pull the radio/ac etc surround of and you should be able to get to it. unless its blocked further down
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
