In need of:
-an intercooler hardpipe kit
- intake kit such as the apexi to suit z32 80mm afm
- gauge pod to mount onto dash
- defi sensor wiring that goes back to controller. Not the sensor itself, just the wiring.that extends back
sump and rocker baffle kit
full heater hose kit
a fabricator to make alloy radiator pipes
radiator breather tank eg Sard, Greddy, etc
located sydney, help wanted from everywhere
https://www.sau.com.au/forums/topic/385027-parts-for-33-gtr/
In need of:
gday there buddy , how are ya , i am sure i can help you out , i am also in sydney as well , fairfield / liverpool area so very convienent for yourself hey
1) so with the intercooler hardpipe kit you after the blue silicon hoses to replace the factory items or wat hardpipe kit do you want to suit your stock r33 gt - r intercooler man ?
2) apexi intake kit to suit a z32 afm shouldnt be a problem man .
3) you after a single guage pod or twin or triple ? also 52mm or 60mm man ?
4) as for the defi wiring , from the controller where does the wiring goto wat sensor or to a guage ?
5) larger sump and rocker baffle kit shouldnt be a problem .
6) silicon full heator hose kit should be sweet az well .
7) did you get the wrong radiator or there isnt any silicon hoses that would match with your radiator to your engine man ?
8) radiator breather tank is no problems at all as well
let me know wat you think
and we can sort this out asap for you hey
thanks anthony
  • 2 months later...
-triple gauge pod to mount onto dash
- defi sensor wiring. wiring that goes between controller and gauge, also both the water temp and oil temp sensor back to controller.
-sump and rocker baffle kit. maybe High octane products?
-full heater hose kit
-radiator breather tank eg Sard, Greddy, etc
thanks to Mattyneweraimports for swift transaction of Greddy solid radiator pipe :)
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
