Thought we'd start a thread realating to the past and current fabrication work we are doing in our sydney workshop.
First up a few previous and very current cages which we've done.
A couple of S chassis both half and full
A few R32/33 chassis with fairly extensive cages
A lotus and Focus RS
Our Regular Fabrication work
180SX alloy door trims, folded over the edges.
Ford F350 alloy washer bottle
Custom alloy surge tank
We have a few interesting projects underway currently.
An on going development FG F6 ute with carbon 4 link suspension
  • Like 1
https://www.sau.com.au/forums/topic/385051-pro-fabrications-pfre-fabrication/
Did you seen the skyline arms in the box opposite the ford stuff Ariel??
That's the gear everyone wants to see ;)
I'll be putting photos of them out there soon.
That cage is in neil's R33 GTsT. The lower horizontal bars have harness lugs and the tunnel bar is there to provide some strength to the trans tunnel over the "bridge" I've seen heaps of people do those lower harness bars and the inner plates just tear off the tunnel in an accident. (so theyshould when the tunnel is .8mm tin can....)
As you can imagine there is some work involved getting a
360deg weld around those floor bars and even more to get a weld around some of the intricate X section roof bars.
In that cage no it's welded to plates on each side of the trans tunnel. The cage wasn't aloud to penetrate the cabin area for the intended category.
Other cages I've done have that same bar passing through the tunnel and making a complete tailshaft loop like your thinking. I'll post up some photos of the underside of said car latter.
I don't think I've seen anyone else doing it like that.
Awesome ally welds.
Would love some tips on how to get such a nice finish. Ive just spent a whole day trying to work out why my tig wont weld ally properly, and I have thus found out how much stainless f**ks (read: contaminates) everything up.....
Hey mate, good to see your having a go.
Being clean is the biggest thing.
Everything relates back to clean, technique comes after that.
If using a guillotine make sure the cut is 2/3rds knife 1/3rd snap. That actually makes a massive difference.
If using a bandsaw/jigsaw make sure it's a dedicated alloy blade.
Dont use a grinding wheel, abrasive will always get bedded into the alloy.
If using a linisher make sure it's a dedicated alloy belt.
Grinding tungstens use a dedicated grinding stone.
Make sure fillers are cleaned, clean gloves, clean bench top etc etc.
Wipe the job down with thinners, alcohol or some type of oil less cleaner before welding.
There is heaps of small things we do every job that are second nature. The process is fairly involved when I think about it in broken down terms
Yes of course AC/DC where appropriate otherwise you wont get anywhere, i already learnt that :)
Yeah thats the thing, its second nature for experienced welders, but if youre self taught and dont have anybody letting you know these little bits n pieces it gets really frustrating sometimes.
I solved my contamination problems yesterday by trying a new belt...cleaning the tungstens and even the ceramic. I also wore so rubber gloves (dont have any other leather ones atm) to stop anything else getting on the ally. I also cleaned the filler rods for the first time (never thought of doing this before) and alot of metal dust n crap came off them!
I didnt know about the grinding wheel thing, thats good, not that theyre very useful for ally anyway.
Another thing is tip profile, some use it sharp and others blunt? My problems have been relating to the arc wondering around everywhere and struggling to keep a pool. Havent tried blunt yet.
Tungsten depends on the machine.
One of my machines is really hard on the smaller 1.6mm ones. Regardless of balance it turns them into a ball fairly quickly.
My other machine is a gem. It can look after the tungsten and keep it reasonably consistent. arc stability comes down to the machine as much as the tungsten.
Is it a big 3phase welder or a smaller single phase job?
Thanks Andrew.
I've been really busy with various projects these are just a few of the minor fab jobs that have been done.
Tony from Wakefield park just dropped off his new Honda integra which is to be started shortly.
Cage, and safety fit out.
Same model Integra as the other ones?
Also, have you done any cages and/or suspension work to 70 Series Supra's?
If not, I have a nice cutaway drawing of a works group A version I would like replicated next year sometime
Thanks Andrew.
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
