Also very interested in the undercar surge you have made brad, looks the goods. Does it tuck up under there nice and high ie. away from harm and is it suitable for a street driven vehicle, and is this same tank/design suitable for a GTR.
Thanks in advance, Allan
The R33 surge tanks suit GTsT and GTR. They won't fit properly into a 4 door r33 though.
They don't hang any lower than the chassis rails.
Some of the larger "race" versions are about 10mm lower than the chassis rails which is how they gain some capacity.
Never had one hit the circuit or ripple strips etc.
talk neil into being the gineau pig. cheryl needs a surge tank to deal with those 150 mighty kw.
Brad,,,rule my car out as the guinea pig,,,Cheryl needs nothing in the fuel dept at the moment. Control your self Handley,,,we are not turning her into a 300kw plus car just yet.
Cheers
Neil.
Dammit.
Alan, I never would have fitted an undercar surge tank to the rally car unless I was 100% happy about how far it sits above the chassis rail. Anything that hits the tank is going to bash a lot of other bits firs
Just checking duncan :) Best to ask the questions, as the ones you dont ask are the ones that bite you :) Brad, if you wouldnt mind, and if you have the time, can you please PM me a rough cost for one of these undercar surge tanks with a pierburg and barb fittings and also a cost for an extended sump with windage/baffles we were talking about earlier. Im happy to do exchange or to send you my unit as the car is in a million bits for the next few months.
Finished off one of the R34 combined overflow/catch can units.
I've managed to utilize the original battery clamp location and weld on a machined pin that locates the tank.
A simple bracket and bolt secures it into an original hole, no drilling required.
I'll post up photos of it tomorrow when I get time.
Sump has left already mike, it went this week so I'd expect it to arrive today or Tuesday.
I put the fittings in a separate bag so they didn't get damaged. Just be sure to clean the inside Before it fitted. They get washed here but Another wash won't hurt it.
This is one of the R34 combination catch cans. Its a radiator overflow and catch can built into one unit.
Catch can is baffled and at the customers request has a 3rd fitting to vent back into the intake as opposed to atmosphere.
Also have one R32 GTR/GTsT infront of battery location catch can left that has 2x -12an fittings welded onto it.
Its $180 inc postage if anyone is after one cheap. Its been sitting around the customer fell off the face of the earth so might as well sell it.
A few hours was taken to put a basic CDS cage into a DC2 type R for Tony the marketing manager at wakefield park.
Nice tight fit with basic intrusion bars to make it easy for him to use.
Has been a couple of weeks since we did a full cage ( put a few off due to alloy fab orders needing to be cleared out)
We also dragged prestige motorsports Time attack S15 out of the corner today. Ill put up a few photos of that latter. It turned into a full house build with carbon suspension and loads of fabrication work.
Couple of cars to clear out next week (AWD R31, STI Andra cage and a 120Y E85 conversion) as well as the S15.
Opening back up for 2012 tomorrow. A couple of new things happening straight up.
A good fabricator and mate of mine is joining us for a while to help out with the prep work and design work
Also a new project is beginning. An idea that's been floating around for a while is to fabricate fuel tank extensions to actually bolt to the factory R32,r33 and r34 fuel tanks. The idea is to have internal pumps with a float type baffle plate that's entirely sealed inside the fuel tank. The extension will act as a surge tank that's self feeding being a part of the main tank.
We've been racing GTR's and nissans for a long time now, everything we sell has been race proven multiple times over so these new components will be no different. Testing prior to sale is paramount.
The old undercar surges were tried and tested so these will hopefully raise the bar a little higher and make things a bit more compact for the circuit guys.
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
