Also very interested in the undercar surge you have made brad, looks the goods. Does it tuck up under there nice and high ie. away from harm and is it suitable for a street driven vehicle, and is this same tank/design suitable for a GTR.
Thanks in advance, Allan
The R33 surge tanks suit GTsT and GTR. They won't fit properly into a 4 door r33 though.
They don't hang any lower than the chassis rails.
Some of the larger "race" versions are about 10mm lower than the chassis rails which is how they gain some capacity.
Never had one hit the circuit or ripple strips etc.
talk neil into being the gineau pig. cheryl needs a surge tank to deal with those 150 mighty kw.
Brad,,,rule my car out as the guinea pig,,,Cheryl needs nothing in the fuel dept at the moment. Control your self Handley,,,we are not turning her into a 300kw plus car just yet.
Cheers
Neil.
Dammit.
Alan, I never would have fitted an undercar surge tank to the rally car unless I was 100% happy about how far it sits above the chassis rail. Anything that hits the tank is going to bash a lot of other bits firs
Just checking duncan :) Best to ask the questions, as the ones you dont ask are the ones that bite you :) Brad, if you wouldnt mind, and if you have the time, can you please PM me a rough cost for one of these undercar surge tanks with a pierburg and barb fittings and also a cost for an extended sump with windage/baffles we were talking about earlier. Im happy to do exchange or to send you my unit as the car is in a million bits for the next few months.
Finished off one of the R34 combined overflow/catch can units.
I've managed to utilize the original battery clamp location and weld on a machined pin that locates the tank.
A simple bracket and bolt secures it into an original hole, no drilling required.
I'll post up photos of it tomorrow when I get time.
Sump has left already mike, it went this week so I'd expect it to arrive today or Tuesday.
I put the fittings in a separate bag so they didn't get damaged. Just be sure to clean the inside Before it fitted. They get washed here but Another wash won't hurt it.
This is one of the R34 combination catch cans. Its a radiator overflow and catch can built into one unit.
Catch can is baffled and at the customers request has a 3rd fitting to vent back into the intake as opposed to atmosphere.
Also have one R32 GTR/GTsT infront of battery location catch can left that has 2x -12an fittings welded onto it.
Its $180 inc postage if anyone is after one cheap. Its been sitting around the customer fell off the face of the earth so might as well sell it.
A few hours was taken to put a basic CDS cage into a DC2 type R for Tony the marketing manager at wakefield park.
Nice tight fit with basic intrusion bars to make it easy for him to use.
Has been a couple of weeks since we did a full cage ( put a few off due to alloy fab orders needing to be cleared out)
We also dragged prestige motorsports Time attack S15 out of the corner today. Ill put up a few photos of that latter. It turned into a full house build with carbon suspension and loads of fabrication work.
Couple of cars to clear out next week (AWD R31, STI Andra cage and a 120Y E85 conversion) as well as the S15.
Opening back up for 2012 tomorrow. A couple of new things happening straight up.
A good fabricator and mate of mine is joining us for a while to help out with the prep work and design work
Also a new project is beginning. An idea that's been floating around for a while is to fabricate fuel tank extensions to actually bolt to the factory R32,r33 and r34 fuel tanks. The idea is to have internal pumps with a float type baffle plate that's entirely sealed inside the fuel tank. The extension will act as a surge tank that's self feeding being a part of the main tank.
We've been racing GTR's and nissans for a long time now, everything we sell has been race proven multiple times over so these new components will be no different. Testing prior to sale is paramount.
The old undercar surges were tried and tested so these will hopefully raise the bar a little higher and make things a bit more compact for the circuit guys.
    • interestingly enough, i found out the answer is yes. doing a flush did fix my recurring A/T light. it might have been because of the trans filter: but that doesn't really make sense to me. the fluid/filter was super dirty. would that increase the pressure in the lines and trigger an A/T light? does the car even have a way of detecting that? i have no idea. i've done 200+ miles after the flush and no A/T light. if my A/B solenoids went bad, i would think the light would've come on. shifts and drives way better now though...at 2k rpm instead of 2500...no hesitation and downshifts when i want it to.
    • I vote go red. Only because I hate keeping gloss black clean. Was no worries helping out either! Glad you've survived the rain outs of QLD
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
