So I had a heater hose under the inlet go on me the other week in traffic. I completely cooked the engine with so much steam coming out the bonnet I had trouble steering down a slip road. It turns out with steam whistling through the system I cracked the overflow bottle. Have you got anything to replace the std reservoir. I may cut and tape up a breather.overflow setup that you can go to town on for me?!?!?
No Ti gear knobs sorry. Solid Ti billets are extremely expensive and rare.
I'm also not tooled to machine it.
No problem at all Roy.
Best to make something up from cardboard chuck it in a box and I'll redo it from alloy plate and send it back.
You shall see it tomorrow, I've just had no time to sit down and invoice anything recently.
About to be released are my new surge tank/pump setups with twin aero motive pumps inside the surge tank, sard style.
Not a problem I'll cancel the invoice.
If anyone wants an R33 undercar surge tank setup for twin 044's I've got one fabbed and ready to pressure test/ post off.
$330 inc gst plus postage charges.
You have a pm.
I don't get on here everyday, the reality is SAU accounts for 10% of my work so I don't always check threads and PM's daily. It's been weekly as of late.
My email is available. Best to contact me via that, or leave a return voice mail.
Any pics of the surge tank Brad? Got a mate that might be interested in one.
Good to see your happy with it.
It's a pretty trick way of doing the washer bottle filler on that can with the filler tube running through the catch can section .
From the top it looks like your putting water into the catch can ;)
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
