100Mm Intercooler On 34 Gtr
sinistaGTR
 Share
Look I have been through this my cooler is stuffed and requires replacement. Can so wine just tell me about the front bar please
my one the front bar was not cut as far as i know [not sure if it was trimmed]
however the cooler is installed slightly angled down so it goes inside the front bar
see pictures... attached
Im using a 100mm Nismo z-tune core and the bar had to be trimmed a little. The tags that hold in the mesh had to go, as well as a few notches to accomodate the welds. This didnt worry me though as I was intending on getting a nismo front bar eventually anyway.
Regarding engine temps, they aren't a problem provided you use a GOOD core like a Nismo or something else high end. Today in traffic I saw 44 degrees as the air intake temp on the MFD. Engine temp will sit around thermostat 68-70 and oil at 80-82. Sitting in traffic stationary with the aircon on will see the water temps rise up to 80ish which is still very safe.
Dam I miss the cool climate of Victoria, and seeing air temps of 10-11 degrees!
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
