Hi all,
I've picked up an AVC-R for a pretty good price and wasn't concerned about installing it until i looked at the pinouts for the M35, now i'm confused.
From looking at the most recent map of the loom into ECU that Leon posted toward the end of the thread below, I'm not sure i can identify the correct wires to use.
http://www.skylinesaustralia.com/forums/topic/266854-m35-emanage-ultimate/page__hl__m35+ecu+pin+out__st__520
Before i spend any more time on this, has anyone done this install yet and can offer any pointers?
The AVC wiring manual can be seen here;
http://www.scribd.com/doc/19579396/Apexi-Installation-Instruction-Manual-AVCR-Wiring-Diagram
I'm confident working on the Stagea and getting stuck into things but i think this is one you don't want to muff up!
Thanks i advance,
Jas
https://www.sau.com.au/forums/topic/385090-m35-apexi-avc-r-install/
I'm afraid I've no experience to help you out with but please keep us updated with your (English speaking) world first install !
PS How's your Russian lol..............
http://www.drive2.ru/p/cjr/OGAAAAAALEE4YAAAAAC8bA
That's a nice boost controller Jason.
Here's how to connect it. PM me if you need further help.
Red - ECU 110
Green - ECU 48 or 57 (choose same wire for black)
Black - ECU 48 or 57 (choose same wire as green)
Purple - ECU 1, 2 or 3 (or even 11, 12 or 13 - whatever's easiest)
Grey - ECU 83
White - TCM 27 (this one is yellow/black :happy: )
Cheers, Leon.
http://www.drive2.ru...ALEE4YAAAAAC8bA
Oh.....misread this......I thought this was a hand controller for the ECU!blush.gif
Edited by Jetwreck
Red - ECU 110
Grey - ECU 83
Cheers, Leon.
I'll keep you all posted on how the install goes and the unit performs.
Yeah, time to brush up on the Russian hey!
Of all the pages I've read on the AVC-R install on our cars, i can't believe i didn't find that one, nice find, thanks.
I have to admit, the translations from Google and Chrome make for a ton of laughs......
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
