Hy guys i have alot of things that now just has to go
Big things i will not sned but pickup is available
in s.e suburbs melb
r33 auto gear box nothing wrong with it and it has done 130xxx $90 bucks
R33 manual box All looks good inside just 3rd gear selector clip has broken
easy fix for some people but i just dont have the tools :) $280
r33 fenders s1 Rig and left not dints or anything but a little bit of paint fade $30 bucks a side
r33 rear bumper Std and in white small scratches could do with a tutch up $35
R33 oem clutch looks like it still has HEAPS left on it CHEAP!!! $25
R33 Tail lights in ok nick $40 bucks for BOTH
R33 s2 rear pods One has a crack in it that has been glued up ( needs paint) $ 25
5 x 114.3 20mm spacers comes with nuts $80 for the pair
S14 Boot with 2 with wing Bit of paint fade on it $30
s14 drvers door without buttons bit of paint fade but somes with motor $40
and glass and all that
Sr20 Exshaust manifold Stainless steel gave me and extra 10kw's ONLY $80
intercoolers ------
Sr20 Trust straight though inter cooler a oldie but a GOODIE comes with $270
piping and silicone
Sr20 Greedy Return style cooler ( comes with piping $250
Hybrid intercooler ( no piping ) $80
Sr20 Std injectors from a s14 only done 110xxx $60
i can get photo's by request otherwise when i have time some will be up on here
0430106414
[email protected]
ok guys things are going fast
Manuel box GONE
tail lights GONE
Fender's Waiting to be picked up
and hese some pics
Return flo ( greddy ) and the straight thorough ( trust ) coolers Both come with all piping and silicone hoses
post-63394-0-04786000-1323650936_thumb.jpg post-63394-0-43597000-1323650941_thumb.jpg
I also have this exhaust tip only ever used to test once does give off that pig pipe noise and i only WANT 75 bucks for it
Pipes are 470 cm an the whole thing is about 10 cm longer
hey mate are you sure the pipes it self are 470cm thats way too long mate. 10cm the whole things is this right??/
just want to change my cannon tips to that pipes
Edited by Dbeast
Hers pics of spacers
( And you are Quite right i had a small typo what i ment to say is 450mm not cm )
That one in the photo is smaller aswell
But i d have these ones i have posted a pic of the size along with a pic of the pipes
And here is an example of what i mean about the size
Edited by Abe2
smoe one rabbed that up within 2 days :) but i can stick a flange on the back of one of these though :) these tend to look and sound alot better also :)
sold the other one so cheap because
it was the first one i ever made
still the same prize $75??? with the flange thats fit r34 gtt
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
