just pulled the engine off the stand and encountered my forst problem with the spool crankshaft. The flywheel bolts need to have a washer on them or shortened due to the factory bolts bottoming out. On to the lathe they go then!
if i found a double jointed female id be pimpin ma DJ hoe fo sho!
No but seriously, im 6foot4, and resemble some large primate species, gorilla like.....i can only just fit my hands in the bloody cavity the bastard goes!
yeah, i got it. ended up removing the alternator and oil filter and going through the front of the engine bay. I despise the starter in these cars, i almost bled to death lol. Its all starting to come together now, just waiting on some ned alt, ac and ps belts to arrive, a new supersnail to arrive and then its off to the fab shop to get a PS resivoir relocated and hotside piping made up along with a dump and exhaust! Pics tonight :)
Well, engine harness is on, cold side is 95% complete, just waiting on a new fuel filter and some fuel line, then i can bang that in, put the cooler hose and radiator hoses on and im on to the injectors! Was considering going a set of "Adaptors to go from the ID's to the standard plugs, but im instead going to remove the old plug and hard wire in a new plug as it looks neater and there is a little extra wire there if in the future i decide to change my mind again.
Id like to give a big shout out to paul, aka PIGGAZ for his help, and also a shout out to the greater SAU community for thier knowledge of all things arr bee!
Now, some boring, but progressive pictures!
On the way in, by yourself, this method makes it an absolute fcuking mission!
In the hole!
And as it sits at the moment, waiting for some precision goodness so i can start routing lines and making a dump!
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
