just pulled the engine off the stand and encountered my forst problem with the spool crankshaft. The flywheel bolts need to have a washer on them or shortened due to the factory bolts bottoming out. On to the lathe they go then!
if i found a double jointed female id be pimpin ma DJ hoe fo sho!
No but seriously, im 6foot4, and resemble some large primate species, gorilla like.....i can only just fit my hands in the bloody cavity the bastard goes!
yeah, i got it. ended up removing the alternator and oil filter and going through the front of the engine bay. I despise the starter in these cars, i almost bled to death lol. Its all starting to come together now, just waiting on some ned alt, ac and ps belts to arrive, a new supersnail to arrive and then its off to the fab shop to get a PS resivoir relocated and hotside piping made up along with a dump and exhaust! Pics tonight :)
Well, engine harness is on, cold side is 95% complete, just waiting on a new fuel filter and some fuel line, then i can bang that in, put the cooler hose and radiator hoses on and im on to the injectors! Was considering going a set of "Adaptors to go from the ID's to the standard plugs, but im instead going to remove the old plug and hard wire in a new plug as it looks neater and there is a little extra wire there if in the future i decide to change my mind again.
Id like to give a big shout out to paul, aka PIGGAZ for his help, and also a shout out to the greater SAU community for thier knowledge of all things arr bee!
Now, some boring, but progressive pictures!
On the way in, by yourself, this method makes it an absolute fcuking mission!
In the hole!
And as it sits at the moment, waiting for some precision goodness so i can start routing lines and making a dump!
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
