So i thought i would finally postup my project seeing as work has now started on it.
As i brought it 12-14months ago
Main body was not too bad.
Rear guards where cut to fit flares.
The damage on the bonnet
taco
Flares that came with the car.
car interior
  • Like 2
https://www.sau.com.au/forums/topic/385126-my-c110-skyline-project/
Now it was time to buy some new parts.
Front Grill, rear bob tail and a front lip
GTR style grill
Was around this time that i started to try fit the Flares that came with the car and decided they would not do. So order a new set from Otomoto.
Plan for now is just put the L24 back in and get rego, possibly triple the 24 if im happy with it.If not the car did have an RB26 sitting in when i brought but really this is the last piece to the puzzle and i dont know what i want but leaning towards old school with triples. Also must be manual so manual pedal box and 5 speed going in.
Ye L24 or similar with triples would be mint
even an ITB EFI setup, so you dont spend 18 hours every saturday balancing the carbs
From what i have seen for ITB motors they dont make the power for the money, For around 9k i could have a bored stroked L28(3.1) with a race ported head make about 100hp per litre at motor
so would make as much or more then a RB30 with ITBs. Rego first tho and worry about motors later.
subscribed... love it!soooo, when your done with this one you'll build me one right?
Hahaha its just finding a good coupe to start with is hard
So after a week at the shop this is what i found.
Guards looking mint now
All that messy cutting cleaned up and repaired.
Engine bay cleaned up.
All rust repaired in doors and body.
Now im starting to see the car coming together took me near 14 months to get to here mostly saving to pay for all the work that needs doing.
Having looked at a few other cars im hoping to fit 16*8.5 -6 and 16*9.5-19 R type Watanabe's when the car is complete.
The day i got it back from paint.
MMMMM now that looks good, but now its over to me to do some work lol
Four days work but the bonnet came up while.
Shinny
Hmmm getting there now only a few updates left till its where the car has been at for the last month of rain!!
Im hoping to fit 16*8.5 -6(maybe 16*8 +0) and 16*9.5-19 R type Watanabe's when the car is complete. Ben from otomoto has 17*8.5 +0 and 17*9.5 -19 with a 25mm spacer on the back of his C110.
But not sure i have as much space as he has, so worried about ordering 2800 dollars worth of rims that will not fit lol.
I had a few mates drop over on the frist weekend i got it back and we got stuck in.
We added some rubber behind the flares to try stop them from cutting into the paint.
Started to fit the wiring loom and new fused box.
got the grill and lights in.
I want to put rubber base"s on the mirrors too.
And the next week i cleaned up the bumpers and fitted them
Also cleaned up rear lights and surround.
  • 1 month later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
