Hi guys I'm just wondering if I would be loosing back pressure and low down torque I have a stock exhaust system but the rear muffler has been changed for a cannon muffler also that exhaust curve before the stock muffler had to be replaced will this affect my back pressure? I still have stock centre muffler but I do also have a high flow cat the car feels a little slower at lower rpm but it could be just me being paranoid as my old exhaust " cat back performance" system made the car a lot slower
Cheers
https://www.sau.com.au/forums/topic/385159-back-pressure/
changing the rear muffler won't do much for performance in either a positive or negative way. it will make the car louder though.
also you need to know that, despite what a lot of people will tell you, you don't want back pressure from an exhaust system, whether it's turbo or natro. back pressure is an unwanted side effect from having an exhaust that flows well at lower rpm. the majority of people will just refer to back pressure when talking exhaust size without knowing what they are really talking about. what you want is an exhaust with optimum flow and minimal back pressure, however this is much easier said than done.
https://www.sau.com.au/forums/topic/385159-back-pressure/#findComment-6143465
  • 3 weeks later...
not a skyline, renault clio, sock exhaust . 2" press bent with lots of mufflers. went to a 2.5" no cat and 2 straight thu mufflers gained 10% @ wheels.
not discounting your gains, but what you said is somewhat of a blanket statement and doesn't show the true nature of the power gains. unless you overlay the before and after power runs and compare the power gains throughout the rev range you can't accurately see what gains you made. the majority of people just look at the peak power output. this can mean that while you may have a car that at the top of the rev range makes more power, but in the low and middle of the rev range (where you spend most of the time when driving on the street) you may be down on power. not saying this is the case for all cars, it's just a generalisation. i've seen plenty of cars with exhaust systems that give gains at the top 1/3 to 1/4 of the rev range, but lose power at the lower end of the rev range. the funny thing is though, because of the slightly steeper power curve, it gives the sense of total power gains. i've also seen exhaust systems that gave no total power output, but lower power in the lower rev range that also gave this feeling of more power.
https://www.sau.com.au/forums/topic/385159-back-pressure/#findComment-6170072
<br />not discounting your gains, but what you said is somewhat of a blanket statement and doesn't show the true nature of the power gains. unless you overlay the before and after power runs and compare the power gains throughout the rev range you can't accurately see what gains you made. the majority of people just look at the peak power output. this can mean that while you may have a car that at the top of the rev range makes more power, but in the low and middle of the rev range (where you spend most of the time when driving on the street) you may be down on power. not saying this is the case for all cars, it's just a generalisation. i've seen plenty of cars with exhaust systems that give gains at the top 1/3 to 1/4 of the rev range, but lose power at the lower end of the rev range. the funny thing is though, because of the slightly steeper power curve, it gives the sense of total power gains. i've also seen exhaust systems that gave no total power output, but lower power in the lower rev range that also gave this feeling of more power.<br />
<br /><br /><br />
Well I think it's better to lose some down low for overall top end. Honestly I think you NA guys should build the engine up WITHOUT a turbo and run a stealthy NOS setup. It doesn't matter if you're a P Plater you can set it up in a stealthy way. This would cost some money though not only the building but I'm not sure if the stock ECU can run different tunes for NOS and non-nitrous but if you have the cash and want alot of power on your Ps then it's the way to go.
https://www.sau.com.au/forums/topic/385159-back-pressure/#findComment-6170545
<br /><br /><br />
for a race car yes, for a car driven on the street, then hell no. if you are making less power below 5000rpm then stock, then you will spend pretty much all your time driving a car with less power than you started with, unless you plan on only driving round in 1st and 2nd gear, and maybe 3rd on the highway. less power at lower rpm results in higher fuel usage as well as a car that isn't as nice to drive on a daily basis. in a lot of cases the difference in drivability and fuel economy is minimal.
https://www.sau.com.au/forums/topic/385159-back-pressure/#findComment-6170617
f**king school holidays aye
i agree with mad082 what's the point in having all that power if it can't be used, n/a or not any motor needs to be built around its main purpose and be practical
Plus im a strong believer of response/ torque is what you should focus on and the power output is just a bi-product.
With the nos idea, to "just whack a nos kit on" is going to kill any motor that is not prepared for it, some stock valves will burn out that never would in normal conditions. cast pistons will crack or melt, forged pistons will eventually melt, "tuff" coated forget pistons will stay coated from 6-20 shots (varying depending on how much is used) leaving a bare forged piston, and im sure there is more in areas i don't specialise in
(wow we did go off topic a bit didn't we)
https://www.sau.com.au/forums/topic/385159-back-pressure/#findComment-6170928
I'll take the car that makes all of its grunt down in the low to mid range rather then up top...
That way you just short shift, and stay on power.
If it's dead down low on power, it's going to be slow off the mark unless you have a shit load of grip and launch it all the time...
https://www.sau.com.au/forums/topic/385159-back-pressure/#findComment-6172045
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
