Hi guys
I have a Bosch 040 fuel pump installed about 2.5 years ago after my stock one died.
I know (from reading here) that the Bosch units always buzz louder compared to stock, however last week while making several trips back & forth between different JB HiFi stores to collect my TV & A/V receiver stuff the car started to make a very loud buzz noise near the end of the day.
It was a 35 deg C day & I have being using A/C all day long, the noise is the same type of buzz noise the fuel pump makes normally & comes from the same location (near the fuel tank) but MUCH more louder, that you can hear it very clearly when accelerating off or just cruising along at 60km/h. Normally the pump buzz noise can only be heard if you tap the accelerator in park/neutral & is standing outside the car.
It only makes this noise after extended period of driving so if I leave the car over night the buzz noise will go back to normal volume.
A local workshop checked the fuel pressure & said it was normal & they didn't find anything wrong with the pump but they also said while on their test drive the same noise didn't occur. I'm assuming because they didn't drive it for long enough (I drove close to 1 hour before the buzz got louder). Also the temperature these couple of days have gotten down from mid 30s down to mid 20s.
At this stage I'm suspecting that the pump could be over heating since both times it occurred was on a hot day & I was driving for extended period of time with A/C on max (oil & coolant temperature was normal though), but how would I go in fixing the issue if the pump was over heating?
Should I just get a new pump installed?
Any other suggestions are welcomed.
Trying to get this shit sorted before Christmas since I need to drive to Albany during that time (430km trip).
Thanks.
EDIT: Also as far as I can tell the car still drives & acts normal when the loud buzz occurs & I had about 1/2 tank of fuel while it occured so it wasn't low on fuel if that is of any use.
Edited by Mayuri Krab
https://www.sau.com.au/forums/topic/385178-fuel-pump-buzz/
I have a similar issue after long drives in the heat. I was trying to think of ways to cool the fuel down like insulating the fuel rail and lines but I guess the easiest would be to fit a fuel cooler in the return line, if I can find room for it...
https://www.sau.com.au/forums/topic/385178-fuel-pump-buzz/#findComment-6143895
So I went & got another fuel pump installed, took for a test drive & the noise didn't occur. But then again these couple of days have being relatively cool (mid 20s) compared to before.
Also noob question:
When you guys talk about fuel cooler, is it just one of those generic oil coolers or are there specific coolers designed for cooling petrol?
Since I can't find any specific ones for petrol on Just Jap website, can only see oil, transmission & FMIC.
https://www.sau.com.au/forums/topic/385178-fuel-pump-buzz/#findComment-6144974
    • That may not be so tricky with a changeover relay (again, with LED indicator only to reduce load on existing headlight + source)  30 to indicator + globe side 86 and 87 to headlight parker + 87a to original indicator + chassis side 85 to chassis/earth repeat on each corner, sorted, no diode required
    • There might have been some "hard core" decalcification going on in the cells to create that noise As for chargers, I stick all our cars on a trickle charger every few months to "clean out their pipes/cells", the Mrs battery in her Mistsu ASX is still running its OEM from new battery 10 years on, and that thing does alot of short drives, and it can sit around for ages without a good long run
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
