If anybody has a set of any of these can you please help me out with the following:
Brand: G4
Piston QTY: 8
Rotor Size: 330x32 mm
Piston Diameters: putting track pads this weekend for Wakie on the 17th, will measure and post back then.
just a quick question in relation to these big brake kits and rather then make a new topic, are D2/K-Sport all same quality? or is one better then the other.
i remember reading a thread about a member having issues with his K-Sport brake kit.
http://www.skylinesaustralia.com/forums/topic/365787-k-sport-brake-review/
so kinda dont wanna experience this dilemma.
Yep they are all the same in terms of quality. They come out of the same factory.
The "review" of the k-sport ones does have a bit wrong with it, ill cover that later. with a write up I'm working on. Just haven't had spare time the past month to sit down and do it.
Hey Ash are you still doing a group buy on these brakes? I'm waiting for it : D
Sure am, almost sorted it out and the pricing, looking VERY affordable with ADR approved lines too :)
Had a set on my car now to test for 4-5 months and am happy with the performance even using the "china" pad that comes with them.
Thanks R31Nismoid!
keen on updates of your group buy.
i did read somewhere before that you were trying a set out and was wondering what happened to it.
I've got heaps of pad left and little motivation to pull the things off.
But the pistons on the leading edge (2) are larger than those on the trailing edge.
The pad for the 330mm and 356mm is the same pad.
If thats true Luke you are in for a world of hurt. Are they off a Range Rover, Hummer etc ? They often come with nice and tasty big brakes but cant really be retrofitted to cars
I'll look again in the next few days but there the same 8pots as the Lambo Gallardo, R8 etc.
They are the same or look the same? For instance people generically call F50 calipers the ones with the 44/40mm pistons. But F50s have a range of part numbers and externally look identical to one another...but have many difference piston combinations. I have see F50s with 46/44mm pistons...and I think the 4 pot Brembo off FPV Fords are similar...at around 48/44mm so if you put them on a Nissan they would be horrible.
So your family of 8 pots may be the same as the Lambo etc but they could be a different part number, and given what you are saying about the piston sizes it could be a horrible mismatch.
Somebody, not sure if it was you posted a while ago they had 6 pot or 8 pots off a Range Rover or something which makes me think they are a risk to buy unless you know the piston sizes or are going for a full custom brake install with big gears, boosters and changed pedal ratios
    • interestingly enough, i found out the answer is yes. doing a flush did fix my recurring A/T light. it might have been because of the trans filter: but that doesn't really make sense to me. the fluid/filter was super dirty. would that increase the pressure in the lines and trigger an A/T light? does the car even have a way of detecting that? i have no idea. i've done 200+ miles after the flush and no A/T light. if my A/B solenoids went bad, i would think the light would've come on. shifts and drives way better now though...at 2k rpm instead of 2500...no hesitation and downshifts when i want it to.
    • I vote go red. Only because I hate keeping gloss black clean. Was no worries helping out either! Glad you've survived the rain outs of QLD
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
