21 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey guys,
So I have been tossing up between the 2.
Right now I am stuck and have read as much as I can up about both options. (yes I used search)
So VCT can be controller for the R32 ECU easily via a window switch ($200 delivered)
Z32 ECU has to be modified to plug into the harness.
Which would you prefer and have you had any bad experiences?
Right now I have lined up a R32 ECU for $100 delivered
Let me know what you would do and which you prefer and why.
Thanks,
Kasko
https://www.sau.com.au/forums/topic/385202-z32-nistune-vs-r32-nistune/
I bought a z32 board just have to get it modded and tuned. Asked the tuner about r32 and getting vct to work with it basically a flat out no, dosent work like that. I want the vct so I went with z32
There's a thread about using 8 vs 16 bit Z32 ECUs in R33's. Cant remember the details but IIRC you can tell them apart using the part number and you need to use the 8bit one.
Maybe this was it from the Hypergear thread: LINKY
Thanks mate,
Had a bit of a read through it all
Even looked at their ECU awhile back.
Think I will just stick with the R32 ECU and just get a Window Switch to controller the VCT.
Wish I read the article explaining how one of those Electronic boost controllers has a VCT switch in it.
I just purchased a Greddy Profec 2 for $379
I may say something unusual here, but I think your choice should not be based solely on availability of either ECU. Are you familiar with electronics, programming and anything like that? Do you like to fiddle with parts and set things up yourself or prefer the work to be done for you by a tuner/workshop?
If you're DIY-minded guy, I'd say you should pick Z32 ECU, 'cause it's been around and been played with for a very long time, is much better investigated, and with some work and research you can add different features to it. If you prefer driving your car more then playing with stuff, then you're better off with R32 one.
I have heard of some minor issues in a few cases with the Z32, from what I read it was only a small subset of them, the 16bit ones and possibly some of the 8 bit ones, I would ask the nistune guys to clarify though.
Knowing that the Z32 controls VCT is a fairly big bonus, however if you need a boost controller and buy an Eboost street or Eboost 2 then that has a window switch built in and can control VCT for you, making it free.
Wiring two knock sensors to the single Z32 input seems to be the cause of issues. So either stubbing out with a 470K ohm resistor (ie no knock sensing) or only using a single knock sensor seems to be the preferred option
On the 16 bit Z32 ECU on my bench it was triggering knock maps (with an SR20 sensor which matches the Z32 ECU) having both connected in so would be having a similar effect on 8 bit ECUs. Sam (dr_drift) was the first one to report these type of issues some time ago. We stay away from the 16 bit all together since it has not been tested and the mapping is different (separate fuel and VE maps not as easy to transfer R33 maps onto)
Z32 ECU availability is another issue with the prices on ebay etc increasing due to their increased usefulness on R33s. Ordered a bunch from one of our workshops in the USA so have some here for modifying but they are starting to increase in price there also
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
