Hey Guys,
Just tried to do a compression test on my RB20 and have given up becuase i think the guage or tester is faulty.
I bought one of the crazysales ones of ebay (its the cheapest) and i must have turned the engine over for the quivelent of about 30 secs (not all in one crank) and the guage was only reading 70psi. I was starting to fell bad for the starter motor so moved on to the next cylinder to make sure the first just didnt have only 70psi but i did the same thing and only got 60psi before i gave up.
Surely i shouldnt have to turn the engine over for so long to get a reading? A few cycles of the piston should give a good result?
The engine was hot, throttle fully open but no oil dropped in the cylinders.
Cliffs: So is there something wrong with my technique or just a faulty guage?
P.S: someone wanna lend me a known working gauge? :D
https://www.sau.com.au/forums/topic/385219-failed-compression-test/
You should be able to get a compression reading in about 5 cycles of the engine. The first cycle will generally give most of the compression reading. If the gauge doesn't behave like that, toss it and get a decent gauge - they're not really that expensive.
You want them to all be within 5%
Though I'd say 60 and 70 psi is too low
I know for a rb26 Nissan recommends a rebuild at 125psi
I'd be getting a second tester and doing it again and then checking factory specs
