Hey guys
Ok i have a fair few parts that are in my garage and need to go.
All parts are located in brisbane but can post anywhere at buyers expense.
Here we go
-RB25 oil cooler with braided lines and sandwich plate $250
-Greddy washer bottle to suit R33 $150
-N1 RB25 water pump $100
-Oil catch can painted black. 2x entry holes. 1x breather hole. 1x return to sump hole $200
-Just Jap blue silicone radiator hoses to suit R33 $50
- RB25 S2 coil pack loom $100
-Z32 AFM (no plug) with apexi pod filter $200
-4 core alloy radiator to suit R33. Unsure of brand $350
-Garrett turbo beanie. Ok condition $100
-Direct clutch services 5 puck button clutch with flywheel to suit RB25 (rebuilt 1500kms ago) $450
-3 1/2 inch cat back, then 4 inch from hot dog back to 5 inch HKS cannon to suit R33 $400
PM me for any questions guys.
Sorry about the pictures.. All taken from Iphone
Edited by RIPS_R33
https://www.sau.com.au/forums/topic/385231-massive-parts-clean-out/
  • Replies 52
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
