Hey guys, sent my stag in.for its major service,running fine and they called me to tell me that its now dropped a cylinder. im shit with cars but know thats a lil bit of a problem, should i be ready to dish out $$$ or could it just be a small thing?
https://www.sau.com.au/forums/topic/385318-major-sevive-troubles/
the first thing that should be checked is the spark. and at a guess, either a coilpack or the coilpack loom is stuffed. i only mention the loom as it would have been removed during the service and the looms can sometimes be a bit brittle with age. it is also common for the coils themselves to start to fail with at there age.
the mechanic should be able to figure it out what the issue is, and the reality is that it could a a number of different things, coilpacks being the most common fault though.
if he does come back and say its coils expect to shell out about $650 for a set of new spitfire coils. the coil pack looms were around the $200 mark last time i saw them.
with a bit of luck the mechanic might not have plugged all the coils in properly, or even used the wrong spark plugs.
Edited by QWK32
For some reason a valve was sticking or some crap, idles and drives fine. A mechanic friend seemed abit unconvinced about what the workshop said.
They said the head may need yo be reconditioned but they are not 100% SURE wat was the cause
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
