Sweet as because I could not find one specifically for the 2.5V6. I found a injen one from the US for the V6 where they only got the 3.5 in 3 power tunes and was curious if it would fit
  • Replies 57
My vq30dd came with a pod filter, why the hate?
Nissan factory airboxs are actually very good. In fact your airbox has flowed 300awkw on a Stagea. Thats with the front panel open. Pod filters are great at sucking in hot air from the engine bay (thus reducing power), generally reducing filtration, and being defectable if not enclosed by the Po po. They add noise but no power.
As I said before....
I have only looked at google images of the VQ25dd.I can't see any reason why a z-tube, wouldn't fit. have a search and look at one.
Make your own "powerduct" or buy one from a sucker thats got a pod filter on a VQ35de, and get a quality panel filter. Intake done. Its not going to get any better than that.
OR
hold off modifying it, wait 1 year, and go buy a turbo car thats easier to mod. I can't see how you'd turbo a DD motor. Its very different to a VQ35de. Just wait, buy a 350z and then go nuts.
I can't see why turbo charging a DD motor would be the different. Finding higher capacity DD injectors might be the only hurdle, assuming the factory injectors can't keep up.
It wasn't the fact direct injection and turbo hadnt been done but the vq25dd issues.
Yeah, we'll I'm glad I'm not doing it. Problems off the top of my head would be the dd injectors, the fact it's either 11:1 or 11.3:1 compression, plus the Strength of the connecting rods, and engine management.
I guess it's one of those things, if you throw enough money at it, it would probably work, but it's really not a cost effective project. Far better to ditch it when on full licence and get something easier.
yeah i agree on all those points!
either wait and get a VQ25DET motor installed (and i rekon youll have a monster) or upgrade later when you can afford to
its easier learning to hone your driving skills on a lower powered car. then upgrade when you can drive better.
Whoa, Iain, is that a can of worms I hear you opening, lol. Although most likely true, I can think of a heap of teenagers/early twenties guys (& gals??) who could drive better than me - on a race track anyway, where there's no worry of a lost licence. Although I might be a better (safer) driver now then when I was 18-20, I certainly don't have the nads for risk taking like I used to.
unless he has been driving for years in gokarts or something - no offence intended - then he isnt 'as good' as driver as some others and still may require the experience (and possibly patience) required on the road.
i still take risks, but i use experience before i attempt anything stupid :P
I totally agree. There was the generalisation, which is normally true btw, that young = not a good driver. I wanted to extinguish the flames before they took hold :happy: .
Pod filters are the biggest waste of time!! They suck on hot air and do nothing!!
The plans are:
-Exhaust.
-Port and polish.
-Cold air intake.
-ECU.
-Good tune.
And see what power I get from that. Saving for a M35 axis stagea
replacing that intake pipe on the NA engines is worthwhile, as is the plenum spacer.
a port and polish? you realise that means the motor has to come apart?
probably not worth it unless you throw in some cams too
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
    • I'm late to the party. Been busy with a newborn... Keeping me up at all hours of the night.  I'll look into purchasing ID 1750's then! Thanks everyone for the concrete evidence.
