  • Replies 40
Yep, that was mine.
Hmm, 750 bucks currently for a leather interior, popup screen, reversing camera and Nismo exhaust which are all in good condition.
Turbo, intake, dump may be okay, but I don't know.
Steering looks fine!!
Oh, and that headlight was fine Alex :P The other one, well that was in a million bits... instantly. Can't believe how readily they disintegrate!
Scott, and what radiator cap to you have Mr. Mishimoto?
http://www.skylinesa..._1#entry5148591
Any Nissan/Infinity dealer in the US, I went through West Covina Nissan for mine, but they are not so cooperative since Tony left.
Might even be some on Ebay Motors.
Should be a bit cheaper now though, I believe my mate got his recently for around the $100 but really needs to make up a couple of brackets.
How much factory bodywork did you need to cut? Any pics?
looks a lot neater with that cover.
Cheers
Yep, looks waaay nicer with one.
If you look at yours, you will see that there is an extra 10-15mm(?) of metal above the square rubber grommets for your hoses.
Cut that in line with the top of the grommets and run a brush with some rust prohibitive paint, then all you need to do is make up a small bracket for the top right section of the cover and cut a little in that area to fit :)
Surely they have some stupid hidden reserve for like 6k?
Yep, I was told they had $6k on it.
You can't cut the plastic cover?
I'm somewhat interested, but I can't find the run through from last time you did the group buy - am I just not searching properly? It's not on here or the 'somewhat awesome' forum as far as I can tell?
You won't find one.
GB didn't go ahead and it was only after I installed mine that I thought of offering the GB.
I think you can cut the plastic cover, but I couldn't see doing so would end up with a satisfactory finish so I cut the top strip of metal instead.
No need to worry Ryan, it is not a big job.
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
