  • Replies 40
Yep, that was mine.
Hmm, 750 bucks currently for a leather interior, popup screen, reversing camera and Nismo exhaust which are all in good condition.
Turbo, intake, dump may be okay, but I don't know.
Steering looks fine!!
Oh, and that headlight was fine Alex :P The other one, well that was in a million bits... instantly. Can't believe how readily they disintegrate!
Scott, and what radiator cap to you have Mr. Mishimoto?
http://www.skylinesa..._1#entry5148591
Any Nissan/Infinity dealer in the US, I went through West Covina Nissan for mine, but they are not so cooperative since Tony left.
Might even be some on Ebay Motors.
Should be a bit cheaper now though, I believe my mate got his recently for around the $100 but really needs to make up a couple of brackets.
How much factory bodywork did you need to cut? Any pics?
looks a lot neater with that cover.
Cheers
Yep, looks waaay nicer with one.
If you look at yours, you will see that there is an extra 10-15mm(?) of metal above the square rubber grommets for your hoses.
Cut that in line with the top of the grommets and run a brush with some rust prohibitive paint, then all you need to do is make up a small bracket for the top right section of the cover and cut a little in that area to fit :)
Surely they have some stupid hidden reserve for like 6k?
Yep, I was told they had $6k on it.
You can't cut the plastic cover?
I'm somewhat interested, but I can't find the run through from last time you did the group buy - am I just not searching properly? It's not on here or the 'somewhat awesome' forum as far as I can tell?
You won't find one.
GB didn't go ahead and it was only after I installed mine that I thought of offering the GB.
I think you can cut the plastic cover, but I couldn't see doing so would end up with a satisfactory finish so I cut the top strip of metal instead.
No need to worry Ryan, it is not a big job.
