Hi guys, just a quick question. I plan to build a project car soon and having a bit of trouble finding a turbo to suit, can this turbo be modified so that the centre section (oil feed and return inlet/outlets) are on the opposite side as shown, I need to have the oil feed to be on the same side as the flange. Is it just a matter of unbolting and turning it around then rebolting it up. I know its only a cheap and nasty turbo but it would work for a starting point. I asked the seller and he doesnt seem to have much of an idea.
http://www.ebay.com....E:X:RTQ:AU:1123
Edited by chris_82
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/
That turbo will probably go like a bag of shit and last one oil change.
You will spend more money making parts to fit that turbo, like dumps cooler pipes and lines then you will buying the turbo ETC.
Buy something decent from the get go, Kando Dynamics are cheap and reliable:
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-RB20DET-RB25DET-2-4-Cover-8cm-T3-V-Band-TD06SL2-18G-/290635791753?pt=AU_Car_Parts_Accessories&hash=item43ab3e3d89
That would be a similar amount of effort to install but would be worth using if you are funds limited. That or a hypergear highflow would suit you better.
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147578
Like i said but few of u actually took note of what i was saying, I know its a crap turbo. But that wasnt what i was asking, i was asking if they can be pulled apart and altered. so thanks sarge thats all i needed to know.
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147658
You wouldn't need to know that if you weren't going to buy one.
You do realize these turbos usually last a run or two on the dyno and then blow?
Make sure you post back your results so that we can say that we told you so.
Of you do decide to smarten up, buy a kando.
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147665
OR hes the annoying weasel coming back like "nah nah, ive been floggin it for 6 months, you're all f**ked!"
To which we sit and play the waiting game :P
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147669
lol u guys burr up easy. or what about this one, comes with a 16psi actuator so id have to swap it out for a 7psi one.
http://www.ebay.com....#ht_6487wt_1396
And yes i will post pics when its all completed
Edited by chris_82
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147706
Oh that ones different. It not only explodes but it has a new technology from china that infiltrates your engine ;)
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147719
Those ebay turbos are great for bush bashers :D. I know a guy who threw one on a old MX6 he had in the paddock, bought turbo manifold, turbo, cooler etc off ebay and got a FPR and a 12:1 vortech FMU....lasted ages with that haha
https://www.sau.com.au/forums/topic/385398-cheap-turbo-mod/#findComment-6147771
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
