lol u guys burr up easy. or what about this one, comes with a 16psi actuator so id have to swap it out for a 7psi one.
http://www.ebay.com....#ht_6487wt_1396
And yes i will post pics when its all completed
Are you just blindly searching "skyline turbo" and clicking on the cheapest one you see?
Seriously do some research!
I had one of those turbos on my VL. They're no good. Made some OK power but there were lots of problems.
If you get one, and I strongly reccomend you don't. Make sure you have the right amount of oil going into it, the seals are made of out play dough so they won't handle any excess oil pressure. You need to warm them up and cool them down very carefully or shit gets rough.
They're just totally not worth the hassle.
I also got a cheap stainless manifold too, spend more money modifying the flamin mongrel to fit and I did on the actual manifold then after a few skids it just cracked. Should have just got a 6 boost or something else awesome.
Also had a shitty 55mm monsta gate that'd jam when it got hot; sometimes open, sometimes closed, not really ideal and it cost me my engine from wicked over boost.
I'm sure there are some people out there that'll say they're OK, but I'd rather just a high flow R34 turbo any day. Or my Garrett GT3076R :D
You're better off lurking the forsale threads on here and getting some decent 2nd hand gear than getting some shit ebay crap.
amen - this post should be stickied :)
Didnt know this thread was still going. What about an R32 factory turbo. 10psi actuator ? Can they be clocked ? I have no water lines on my car so do u think they would crap itself being oil fed only ?
I know this is the wrong section. I put some new wheels on my car yesterday. Hiro gold 19x10.5 and 19x9. Whats yous think. Had to roll the rear guards.
Now i have my cooler to install
Wut
Not sure why you would have the water lines blocked off assuming it's still rb25.
Rb20 turbo will fit very easy but will struggle to flow any great power ,still probably make 170rwkw on 14psi. If you are on that tight a budget then rb20 turbo really isn't a bad idea assuming your getting it for $50. For $250 you could get a r33 turbo and make 200rwkw with r32 acuator.
If it's still rb25 then grab some standard water lines and bolt them in with a standard turbo and enjoy good power at a cheap price with some reliability.
Oh no sorry dude this isnt for my 33, It was for a different car im going to build. I wasnt sure which turbo would suit but at this stage im gonna go with a Kando. An R32 turbo would be a good option but soon figured i couldnt get the exhaust dump pipe to work. (curves the wrong way to which i need)
You do know you deliberately posted photos of a 33 in that post right?
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
