hey guys selling my r32 4 door really tuff car
nice to drive and looks sweet
4 door r32 skyline
rb25
rebilt 25 gearbox
front mount
boost controler
3inch zorst
bosch 040 fuel pump
centrol locking
electric windows and mirriors
adjustable camber arms
projector lights
cd player
18 inch rims good dish on the rear
good tyres all round
211 rwk
$10.000 O.N.O
located south australia
call or msg dale 0413800741
msg for more pics
https://www.sau.com.au/forums/topic/385443-r32-4-door-rb25det/
  • 1 month later...
  • 3 months later...
