thanks to these forums I've fixed my minor problem.
I'm no mechanic.. dnt really touch the parts. only thing I've done myself was fit in a bigger battery when the smaller one shitted itself & fitted in an 040pump all with abit of reading.
so me 32 had a problem, not too major, but i was putting 2&2 together with countless hrs of reading.
a drive usually on a warm day or not, with a little bit of giving but never too much, would see my water temps rise and sit above 180+ and nearly approaching 200-220+ with a more give. there were a few occasions where to point the coolant reservoir was spitting out.
so, bought me a new 40mm alloy radiator/hd hoses, nismo low temp thermo & greddy cap. I was also due for a timing belt service so I got me a gtst 100k timing belt kit from Kudos Motorsports/upgraded belt to gates & got the added water pump with it. (was thinkn the N1 but =/) I thought I may aswell do these 2 upgrades the same time together.
props to kudosmotorsport.com for timing belt kit/thermo∩ & jjr for the radiator&hose.
wow @ kudos for their service & delivery.
that done n. dusted, I can give this thing xtra more push :) and not see the water temp rise above 150-160 or 65-71 degrees whatever the weather
thanks yew guys <3 & fanks to my bud for giving me the time to fit these in.
https://www.sau.com.au/forums/topic/385464-r32-minor-overheating/
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
