Hey, i have an R33 Gtst and i just replaced the fuel pump with a Walbro Gss342 and since doing so have had trouble getting anymore than 40 psi at the regulator, its a brand new regulator and i tried two gauges with same results. It seems that the pump is struggling to make pressure does this sound like a faulty pump or something else, any advice would be much appreciated.
https://www.sau.com.au/forums/topic/385465-fuel-pump-problem/
Okay I re-wired the fuel pump this afternoon checked the voltage was 13.8v got good fuel pressure while the engine was cold and screwed the reg back to 44 psi, after going for a short drive and warming the engine up i can't get any more than 40 psi again with the vac hose disconnected even if i screw the regulator right in.
It's definitely fixed now decided to put a direct earth wire to the battery, straight after doing this i noticed the difference and the fact that it pumped up to 100psi so i screwed it right back to 44psi no vac hose and everything seems normal now but makes me wonder might have a crappy earth connection somewhere where does the earth connect to on the body i see the battery is connected to the body buy where does everything else get its earth.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
