Hey Norman, got a nismo MFD...
If I got the intake smoke tested is that likely to show up any leaks that my method didn't?
Bsa - nope, didn't replace any vac lines but I couldn't find any signs that any were damaged. The car went into the garage fine - put an oil filter relocation kit on it, and now it doesn't idle... very frustrating trying to track the problem down.
sounds like they didnt set the nismo mfd correctly, this wouldnt be effecting your idle however just wrong % shown on the mfd.
smoke test depends on how they do it. best way is do the 'start ya bastard' test. spray some around the vac hoses if the revs go up you found the leak.
let me know if you need a hand
Yeah, I sorted the MFD issue by rotating the TPS - now reads 0-95% or something, which is better than before...
Can anyone suggest any electrical diagnostic tests I can do which might help to point to the problem? If I got hold of a wideband oxy sensor would that enable me to determine if I have a vac leak? (i.e. car would be lean at idle?) Is there anything else I can do?
Ok, so I think I've finally fixed it!
Connected the standard ecu and started it up to try and log any fault codes - car idled fine, maybe a little too low ~600rpm.
Didn't stall at all after about 5 mins of idling and on/off throttle so I hooked up the PFC - all good there too...
Car was still idling too low though and was struggling a bit, so I wound out the idle screw and got it back up to 800rpm - idled smoothly after that.
So what changed???
My theory now is that the remote filter and oil cooler put extra strain on the oil pump and because my idle was probably too low already it couldn't keep the engine turning... Today's warmer weather probably helped it a bit and now that I've set the idle higher it shouldn't be a problem. If this is not the reason then I have no idea, the car has magically healed itself...
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
    • I'm late to the party. Been busy with a newborn... Keeping me up at all hours of the night.  I'll look into purchasing ID 1750's then! Thanks everyone for the concrete evidence.
