Hey Norman, got a nismo MFD...
If I got the intake smoke tested is that likely to show up any leaks that my method didn't?
Bsa - nope, didn't replace any vac lines but I couldn't find any signs that any were damaged. The car went into the garage fine - put an oil filter relocation kit on it, and now it doesn't idle... very frustrating trying to track the problem down.
sounds like they didnt set the nismo mfd correctly, this wouldnt be effecting your idle however just wrong % shown on the mfd.
smoke test depends on how they do it. best way is do the 'start ya bastard' test. spray some around the vac hoses if the revs go up you found the leak.
let me know if you need a hand
Yeah, I sorted the MFD issue by rotating the TPS - now reads 0-95% or something, which is better than before...
Can anyone suggest any electrical diagnostic tests I can do which might help to point to the problem? If I got hold of a wideband oxy sensor would that enable me to determine if I have a vac leak? (i.e. car would be lean at idle?) Is there anything else I can do?
Ok, so I think I've finally fixed it!
Connected the standard ecu and started it up to try and log any fault codes - car idled fine, maybe a little too low ~600rpm.
Didn't stall at all after about 5 mins of idling and on/off throttle so I hooked up the PFC - all good there too...
Car was still idling too low though and was struggling a bit, so I wound out the idle screw and got it back up to 800rpm - idled smoothly after that.
So what changed???
My theory now is that the remote filter and oil cooler put extra strain on the oil pump and because my idle was probably too low already it couldn't keep the engine turning... Today's warmer weather probably helped it a bit and now that I've set the idle higher it shouldn't be a problem. If this is not the reason then I have no idea, the car has magically healed itself...
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
