  • Replies 49
this might be some coincidence but i got a wheel alignment done today and my front toe was completely out of whack, fixed it up and the brake squeel is gone??!!!
i am amazed by this, got rid of the annoying squeel and the car is handling better then ever!
either toe or castor will do this .... if your old castor rods are worn under braking they will move forward slighly and increase the squeeling noise.... i have DBA 4000s and bendix ultimates and had this issue... i while aligned it, put the red goo on and filed the edges of the pads down slightly, i then Bleed the front calipers! and its gone!! however it has come back every so slightly as my front right caster is rooted and moving forward a bit so check those out before going crazy with goo and new pads etc....... i know the skylines castor rods a prone to failing after a few years or hard driving ;)
wow the quietness was short lived, its back now,
perhaps the pad and/or rotor is glazed causing it to squeel again, might consider machining the rotor slightly and rubbing some layer off the pad and add some more goo and try again.
  • 1 year later...
Hey guys,
I trawled the net looking for solutions to my brake squeal. I found this thread, used some ideas from it as well as others - the solution I have worked 100% - I have now had zero squeal for close to 8 weeks, washed the rims, rain, brake dust, everything - all been perfect. The reason I was so determined to get rid of it was I am using the skyline as a daily now and sitting in crawling traffic everyday was disgusting.
Car: R33 GTS4 with GTST calipers and slotted rotors that got machined when putting in the new pads
Pads: New QFM HPX, no shims
Squeal: ONLY the front driver's side - loud as f*ck under low speed braking, otherwise everything was silent.
Solution:
1. Cleaned all the grooves of the slotted rotors as they were really built up
2. Ruffed up the pad face to bed it in again using a wire brush
3. Used a cheapo no name brake cleaner and sand paper to clean up all brake parts including the locking pins that hold calipers in and this funny looking thing: post-36975-0-63760800-1366934611_thumb.jpg (NOT the pistons or rubbers boots around them though)
4. I wanted to ensure this metal piece was in the correct shape so I took off the other one from the front passenger's wheel and noticed it was bent a little bit out of whack so bent it back.
5. When I first got my car serviced years and years ago someone must have used that disgusting red brake goo on my caliper's and it was all tacky and black on the pistons and boots, I sat there for a good 30 mins picking it off everywhere until it was all gone and gave the pistons a very light dry sand just to get back to metal.
5. I happened to have a spare front caliper in my garage that had an original set of shims - I took them off, gave them a massive sanding until they were spotless: post-36975-0-25699400-1366936011_thumb.jpg
6. I then got a tub of Penrite copper eze http://www.penriteoil.com.au/products.php?id_categ=15&id_products=108 post-36975-0-58950900-1366937764_thumb.jpg and applied a thick, even layer to the pistons, locking pins, shims and the back of the pads
7. Reassembled everything back together and bedded in the front brake pads again, it's been perfect ever since.
Hope this helps others.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
