Bit of a clear out of parts I no longer need, reasonable offers considered. I will add more as I remember.
1. Bosch 044
Limited use, two available. Was going to run twin pumps but going with a large single instead.
100each
2. HKS DB Chrono Boost and Oil Pressure Gauges
Include all cables, control unit and sensors. Pricey buggers no longer in production. Very slim profile (can easily be double sided taped anywhere on the dash). Have peak recall, replay and all that jazz refer here for full description:
http://www.nengun.com/hks/db-meter-chrono
300 for the pair
3. Surge Tank
Includes 6AN hose tail fittings. Bottom outlet is -10AN.
120ono
4. Optima Yellow Top Battery
Limited use. Presents as new. Terminals included.
330ono
5. RB26 Long Motor
Standard rb26 head
Arias forged pistons, N1 oil pump
Std bearings etc
Completely rebuilt ~10k km's ago, leakdown was in the 18-22% range when last checked. This motor didn't have any piston slap when cold but did use a reasonable amount of oil (built with generous tolerance's by previous owner).
Ideally suit rebuild/freshen up.
Does NOT include cam covers, sump, plenum, balancer or any ancillaries.
1500
6. TIAL 50mm BOV
Black, un-marked. As new
200ono
7. WEDS TC005 17 x 9.5 +30 forged
Ultra-light (7.3'ish kg per corner) wheel with concave face. Easily clear 355mm brakes as pictured.
1750
8. Greddy Oil Cap
Blue.
100ono
Will post anywhere in Aus, buyer pays shipping.
PM or email [email protected]
https://www.sau.com.au/forums/topic/385541-fs-weds-tc005-17-x-95-30-forged/
044 internal or external and 50mm bov plumb back or not?
BOV isn't plumb back.
As the guys above said, 044 can be run in tank or external but these two are spoken for.
No probs Rob.
Had a few queries on cost to ship the wheels, freight to most area's is ~120 using TNT road. Obviously a lot more if you live in the middle of no where!
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
