Honestly i would expect better from a mod but come on the guy asked a pretty simple question.
What is the recommended spark plug gap for the RB25DE is it really that hard to answer.
Maybe he wants to change plugs who knows his post didn't really leave mush for detail but he did ask what gap he should run.
For the record i have NGK BCPR6ES plugs i would also like to know what gap i should be using
Edited by brat81
well you can expect all you want, but i asked for very simple information in order to give him a better answer. he asked if he should gap the plugs (in other words, should he alter the gap). i simply wanted to know what gap he was running so i could give him an accurate answer. you said yourself his post didn't have much detail, so why be upset when i ask for more?
if a mod asking for info is bad form in your eyes then you are going to be regularly dissapointed on this forum. since this is a question that has been, believe it or not, covered hundreds of times, most mods would've simply said "use the search function" or simply not posted at all.
to answer your question about what gap you should be running, stock gap is 1.1mm, but anything between 0.6mm and 1.1mm is perfectly fine. the bigger gap the better, but sometimes you need to reduce the gap below 1.1mm to make up for weak coilpacks.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
