post-63334-0-65446500-1323759385_thumb.jpgpost-63334-0-52421600-1323759511_thumb.jpgpost-63334-0-14914300-1323759487_thumb.jpgpost-63334-0-66039500-1323759462_thumb.jpgpost-63334-0-82790400-1323759427_thumb.jpg1990 R32 GTR
BLACK
BODY OD: 120,000
BODY:
18x9.5 +12 WORK EMOTIONS CR KAI ONLY DONE 8000KMS NO SCRATCHES
STANDARD BODY KIT
CARBON FIBRE EYELIDS
HID KIT
DRIVING LIGHTS
WINDOW TINT 35% LEGAL WITH PAPERWORK
ACCESSORIES:
VIPER ALARM WITH TOP OF THE RANGE COLOUR PAGER WITH REMOTE
START, TURBO TIMER, WINDOWS CAN BE PUT UP FROM DISTANCE, BLUE NEONS UNDERCAR WIRED TO ALARM, ($1,500)
SWITCH IN CENTER OF CAR FOR 2WD/4WD
PERVIOUS OWNER HAS CHANGED CENTER GAUGES BUT I WILL INCLUDE STANDARD SINGLE DIN SET.
JVC HEAD UNIT:
PIONEER SPEAKERS ALL ROUND
AMP SUPPLYING 4 SPEAKERS
STEERING WHEEL HAS BEEN RE-TRIMED NEAR NEW CONDITION
320KM TACHO
AIR CON CONTROL HAS BEEN RE-LOCATED TO GLOVEBOX FOR ROOM FOR DOUBLE DIN HEAD UNIT OR MORE GAUGES (HAVNT FINISHED)
HANDLING:
J.I.C MAGIC ADJUSTABLE COILOVERS (FRONT LEFT HAS LEAKED AND NEEDS A REBUILD)
ADJUSTABLE REAR CAMER ARMS
BRAND NEW BRAKE PADS ALL ROUND
PERFOM:
GARRETT 2860s WITH XFORCE HIGHFLOW DUMPS ONLY 8000KM OLD
ALL NEW HEATER HOSE LINES
BLITZ DUEL SOLENIOD BOOST CONTROLLER
TRUST 3.5INCH EXHAUST WITH DE-CAT PIPE INTO TRUST 5 INCH RESS (CAT COMES WITH CAR)
SARD AIR INDUCTION KIT
NISMO TWIN PLATE COPPER MIX CLUTCH 8000KM OLD
OIL CHANGED EVERY 5,000 KMS
MADE 285 AWKW ON SAFE EVERYDAY TUNETHE ENGINE HAS STARTED TO MAKE A KNOCKING NOISE, UNSURE OF WHAT THE EXACT KNOCKING IS
$11 000 WITHOUT WHEELS
$13 000 WITH WHEELS
May consider swaps for another import
Msg 0432590291
Please dont call as i cant answer during work
Edited by sleeper_13
https://www.sau.com.au/forums/topic/385622-sa-r32-gtr/
JUST TO LET EVERYONE KNOW THE CAR HAS BEEN SITTING IN A GARAGE FOR ABOUT 9 MONTHS NOW SINCE THE KNOCK STARTED I STOPPED DRIVING STRAIGHT AWAY. THE ENGINE STARTS BUT I WOULDN'T DRIVE IT HOW IT SOUNDS, I HAVE A VIDEO TO SHOW HOW THE KNOCKING SOUNDS WITCH I TOOK STRAIGHT AFTER IT FIRST STARTED KNOCKING. THE CAR HAS ONLY RAN FOR ONLY ABOUT 20 SECONDS WHILE KNOCKING BECAUSE I DIDN'T WANT TO DO ANYMORE DAMAGE.
https://www.sau.com.au/forums/topic/385622-sa-r32-gtr/#findComment-6151911
Sorry mate not after an auto.
For engine bay pics can you please txt and I can send.
I'll try get some on here as quick as I can but I'm finding it easier to just txt the pics latly due to not having much time on a computer
Cheers
https://www.sau.com.au/forums/topic/385622-sa-r32-gtr/#findComment-6152670
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
