Hi Guys
I'm looking at the Deatschwerks DW300 pump for my 275rwkw RB25 anyone got any experience, comments or other options to consider?
I currently have a Walbro that is only a couple of years old (low kms) and failing me badly (reaching it's limits @450HP?) :down:
NISMO pumps flow 276lph @ 43psi and I haven't seen a pump yet that doesn't drop off at higher pressures so I'm not convinced they will be any better then the DW300 (they are also 3 times the price!)
The Bosch 040 is weak as piss... the other option is to put a 044 in-tank but the Deatschwerks looks like an easier fit and will meet my power requirements without going OTT
Would love to hear your learned comments and feedback :thanks:
https://www.sau.com.au/forums/topic/385625-deatschwerks-dw300-fuel-pump/
I put the Deatschwerks in mine. It is much quieter than the Bosch 044 & with the fuel relay upgrade in the DIY forum, that solved all my fueling issues. Also put in a Nismo adjustable fuel reg as advise from my tuner. Car is making 328rwkw on 20psi.
How does the Deatschwerks compare in size with the 044? My Bosch works fine but the surge tank is in the back of my Stagea and even with a well insulated steel box over it its still quite noisy. Wonder if the Deatschwerks would fit in the same space (o/a length is the most important).
DW301 is the exact same dimensions as the Walbro but it is an in-tank pump unlike the 044
Yes people are doing that... you should also install a one-way valve apparently and a it's bit of mucking around to fit the pump & sock
The 044 pump is designed to lie flat (that's why you need the one-way valve for an in-tank install) and I have heard of people (on forums) having reliability issues with the pump when it is installed in an upright position.
Call me old fashioned but when it comes to the fuel system I'd rather not take chances using devices for purposes they weren't designed for... again...
OK I f^cked up with the Walbro :D
The 044 would work well in-line with the Walbro feeding it but I am off the Walbro big time after this experience and relying on 2 pumps when you can get away with one seems stupid unless your utilising a surge tank
The 044 can be run in tank if you put the sock over the end.
I would be looking elsewhere if your running out of fuel at 275rwkw. Walbros can flow a lot more than is needed for that kind of power :whistling:
For example at 13.5V and 70psi they flow around 220L/hr which is enough to feed your 550cc injectors plus a little bit more :)
Agreed it should be OK according to those figures and there seems to be plenty of people running higher power levels than me with these pumps
However I'm not the only one that has had problems with the walbro at these power levels
Have a look at my other thread here to see the symptoms I'm having and other peoples comments
It certainly looks like it could be the pump at this stage... I was very careful but maybe I got a dodgy one? (if it is fake it is a bloody good fake!)
http://www.skylinesaustralia.com/forums/topic/385690-r33-fuelingknock-issues/
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
