Sorry for sounding stupid but I know very little about turbo sizing and what all the numbers mean.
I have in my possession a turbo that I was told is from an RB25 but noone knows for sure.
There is very little on it to say what it is so I hope someone on here can help me to decipher it.
The compressor housing has 45V2 on it and nothing else apart from "nissan".
The exhaust housing has 21U and 928A on it.
There are no AR numbers or anything.
Does this mean anything to anyone?
https://www.sau.com.au/forums/topic/38565-what-turbo-is-this/
Boost pressure has nothing to do with it - it's all about shaft speed.
If you increase the VE of the engine (ie a set of cams, or new inlet manifold, or exhaust system) you will find that the turbo will now fail at, say, 11 or 12 psi, as higher engine VE = more compressure RPM for the same boost.
:O
Cheers,
Matt
Well, technically boost pressure *does* have something to do with it, because on the stock turbo, at a given psi, you'd know that the shaft is spinning at X rpm... so we know that at around 13-14psi, the shaft on a stock r33 turbo would be doing the magic 'breakpoint' of X rpm, and would break itself into teeny bits and pieces.
I'm not following your example... feel free to enlighten me on what 'VE' is... but anyway... I disagree with it. :O
When the shaft is doing X rpm, it will fall apart, and you can use the fact that the *stock* impeller, will be pushing X PSI at that point. Even if it was spinning up faster or slower, that won't effect the shaft speed at which it'll break. Changing your cams or a manifold or exhaust system won't change the fact that the turbo will break at roughly X rpm, and thusly, will break when the stock impeller is generating 14+psi. Those mods won't change the spool profile of the stock turbo.
Edit: I've actually walked away and thought of something. I apologise, you're dead right: with a bigger intake manifold, tehre's more space for the turbo to fill up, therefore the turbo will be at Breakpoint rpm, but not reached the magic 14psi. Therefore, it will break at a lower psi. However, if the intake/manifold is stock, and the exhaust is changed, or the cams have changed, it won't break at an earlier psi, it'll just reach that psi faster.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
