Sorry for sounding stupid but I know very little about turbo sizing and what all the numbers mean.
I have in my possession a turbo that I was told is from an RB25 but noone knows for sure.
There is very little on it to say what it is so I hope someone on here can help me to decipher it.
The compressor housing has 45V2 on it and nothing else apart from "nissan".
The exhaust housing has 21U and 928A on it.
There are no AR numbers or anything.
Does this mean anything to anyone?
https://www.sau.com.au/forums/topic/38565-what-turbo-is-this/
Boost pressure has nothing to do with it - it's all about shaft speed.
If you increase the VE of the engine (ie a set of cams, or new inlet manifold, or exhaust system) you will find that the turbo will now fail at, say, 11 or 12 psi, as higher engine VE = more compressure RPM for the same boost.
:O
Cheers,
Matt
Well, technically boost pressure *does* have something to do with it, because on the stock turbo, at a given psi, you'd know that the shaft is spinning at X rpm... so we know that at around 13-14psi, the shaft on a stock r33 turbo would be doing the magic 'breakpoint' of X rpm, and would break itself into teeny bits and pieces.
I'm not following your example... feel free to enlighten me on what 'VE' is... but anyway... I disagree with it. :O
When the shaft is doing X rpm, it will fall apart, and you can use the fact that the *stock* impeller, will be pushing X PSI at that point. Even if it was spinning up faster or slower, that won't effect the shaft speed at which it'll break. Changing your cams or a manifold or exhaust system won't change the fact that the turbo will break at roughly X rpm, and thusly, will break when the stock impeller is generating 14+psi. Those mods won't change the spool profile of the stock turbo.
Edit: I've actually walked away and thought of something. I apologise, you're dead right: with a bigger intake manifold, tehre's more space for the turbo to fill up, therefore the turbo will be at Breakpoint rpm, but not reached the magic 14psi. Therefore, it will break at a lower psi. However, if the intake/manifold is stock, and the exhaust is changed, or the cams have changed, it won't break at an earlier psi, it'll just reach that psi faster.
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
