Hi All, got a bunch of parts leftover from a R34 GTT Front Cut at 113,000kms.
These are the parts for now, will likely add more as time goes by or as I have the rest of the parts.
All items are pick up from Wollongong or postage at buyers expense for most items.
R34 GTT Brake Booster and Master Cylinder - $120.00
R34 GTT Starter Motor - $40
R34 GTT Handbrake Lever - $20?
R34 GTT Windscreen Wiper Motor? (Correct me if it's something else) - $30
R34 GTT Front Shocks and Springs - $100
R34 GTT Front Hubs Assembly with brake discs - $160
R34 GTT SMIC Intercooler with duct shroud - $70
R34 GTT Power Steering Pump - $80
R34 GTT Coolant Reservoir - $40
R34 GTT Washer Bottle with pumps - $50
R34 GTT Air Con Fan and Radiator (together) - $80
R34 GTT Air Con Compressor - $80.00
R34 GTT Clutch Radiator Fan - $50.00
https://www.sau.com.au/forums/topic/385655-leftovers-from-r34-gtt-half-cut/
Hi Mate
The bare shell was already collected a few weeks ago. I can ask my mechanic where it ended up for you to see if it's still available.
Front shells been munched already.
Should still have the entire steering rack not sure on condition of the boots though. I'll stop in tomorrow at my mechanic and check
Also have the majority of an RB25DE NEO Motor.
Bottom End and Head (still attached)
Will sell with or without GTT Injectors depending on price offered.
No throttle body
Appears to have low compression on a cylinder (temperamental)
Need it gone before xmas
R33 Series 2 Turbo with approx 110,000 kms - $280 PP
R34 GTT Throttle Body
R34 N/A Auto ECU $50.00
Will add more again later tonight
talking about the black air con fan? prefer to sell it as one piece..not very sellable a fan without a shroud. PM me an offer and we'll go from there =]
Hi Mate
Should still have the motor... will need to contact my mechanic sooner than later if serious hopefully it hasn't gone yet. I know that they're closed for a couple of weeks but I should be able to see if they still have it in the workshop.
Don't have the loom, but do still have the ECU to suit RB25DE NEO A/T Transmission.
Motor doesn't have throttle body anymore but I can supply the RB25DET NEO Throttle Body. Still have injector rail if you need that. No Exhaust manifold unless you want a turbo manifold with/without an R33 Turbo.
Will be looking at $400 for what's left off the motor essentially bottom end and head, plus pickup/delivery arranged at your cost.
I'll upload a photo of how the motor is now shortly.
PM sent to purchase the windscreen washer bottle with pumps; delivery to 5164.
Let me know a price for supply/postage & I'll buy it from you.
Thanks, Brendan
S1 AC? i take it you're referring to the climate control unit? if so yes I have it, and the metal brackets that hold it and the stereo etc.. in place.
Let me know
  • 6 months later...
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
