Car has very low kms 75000KM. imported in 2003 Has not had rego for about 5 years HAS BEEN SITTING IN SHED AND OUT SIDE I have cleaned car up painted it etc and getting ready to rego.
RB25DET motor has good compression and runs really smooth.
Gearbox is in excellent condition and clutch is strong ( unsure what type it is)
Is not 100 % ready for rego it needs front windscreen also needs its front bar sprayed and fitted (Comes with the black paint) original bar with nice extra lip. Needs boot carpet and inserts. Rear windscreen rubber and battery.
Has Tein fully adjustable coilovers in as new condition very firm unsure of kg rating, 4 wheel steering lock bar, Front mount intercooler, Momo steering wheel, Nice dish 18 inch wheels 8 inch wide front and 9 inch wide rear, 3 1/2 inch exhaust system, Stainless steel jasmo sr muffler,Blow off valve, alloy radiator and thermo fan (not hooked in yet) Interior is clean, car was re-sprayed 12 months ago just sitting in a shed since. Stereo is not working. Runs and drives perfect.
This Car would make a great regoed track car or just a decent street car
after $5250 ONO LOCATED IN MORISSET NSW
CAN SEND EXTRA PICS
Contact 0411672105
https://www.sau.com.au/forums/topic/385716-1995-r33-gtst-manual-5250/
Hi mate
can you please send me some more pics
[email protected]
Thanks
Chris
car is on ebay now past reserve so bid if u want it
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
