Hey guys,
Item: I have an AUTRONIC SMC HC WITH 500R CDI ECU with RB26 loom, high current injector drivers and auto tune 500R CDI ignition included ($1,100 alone) can supply matching CAS if needed, Mazda 13B turbo twin post coils x3 (3" spark!)
Price: $1,700.00 ONO DELIVERED to anywhere on mainland Australia.
Condition: Fine. It came off Dave's (T04GTR) car. I bought it and never used it
Payment: Direct debit to my account, Or cash on pickup (if in Sydney)<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break">
PS: I bought this off Dave (T04GTR) a few months ago and never used it.
I will lay it all out on the floor and take a few photo's when the car isn't in the garage.
https://www.sau.com.au/forums/topic/385717-autronic-smc-hc-with-500r-cdi-ecu/
Huge setup for the money. Here's specs for those interested;
USAGE
These systems can cater for the requirements of virtually any spark ignition engine, including the following: -
High output supercharged or turbocharged engines, with either multi point and/or
centre point injection.
Rotary (Wankle) and two stroke engines.
Engines having uneven firing sequences such as 2 and 4 cylinder ‘V’ configuration motorcycle engines and V6 motor vehicle engines.
FEATURES
Eight injector drivers for full sequential operation on engines up to eight cylinders. May be set for ‘semi-sequential’ operation on engines having more than eight cylinders, eg: - 12 cylinder engine using 6 groups of 2 cylinders.
All injector types catered for (0.9 ohm to 16-ohm coil resistance). Specify unit fitted with optional high current injector drivers for 0.9 ohm or twin injector applications.
User choice of manifold absolute pressure or throttle position as engine load input. Internal absolute pressure sensor for simplified installation 0 to 200Kpa (o to 29.4 PSI) and 0 to 300Kpa (o to 44.1 PSI) available from stock. 0 to 45Kpa (o to 66.1 PSI) available on request.
Single coil distributor, twin coil distributor or multicoil distributor-less ignition configurations are possible on most engines.
Fitted with environmentally sealed connector the standard unit is splash proof. Units are available with double environmental sealing for use in the most arduous of applications (eg: - rally, off-road, and marine).
Auxiliary output function that can be used for any of the following:
Closed loop (feedback) boost pressure control for turbo charged engines with rpm and temperature dependent calibration characteristic.
Closed loop (feedback) idle speed control.
Control of engine cooling fan.
Programmable on/off control for solenoid or relay driving that operates according to engine speed and load (eg: - can be used for gear shift control or light, over rev indicator, inlet camshaft timing selection or control of a supplementary electric fuel pump that augments mechanical fuel pump delivery at low engine rpm only).
Fuel used pulse output to electronic or electro-mechanical counter with resolution of 0.1 litre (or use with trip computer).
Or even more sophisticated control function such as servo control of auxiliary butterfly for turbo charged applications requiring precise throttle control and minimum turbo lag.
Exhaust oxygen sensor input for sensing air/fuel ratio. Connect the low cost AUTRONIC 02 Sensor directly or for more demanding applications the AUTRONIC Wide Range Air/Fuel Ratio Sensor and Meter. The low cost sensor requires no interface adapters or expensive air/fuel ratio meters, and offers moderate accuracy and tolerance to leaded fuels. This function can be used to monitor air/fuel ratio during engine tuning or can be used for feedback control of air/fuel ratio for applications requiring exhaust catalytic conversion (feature available on request).
Diagnostic/Error indicator of sensor or ECU fault conditions with memory for detection of intermittent fault conditions. An external light may also be connected for remote indication of abnormal operation.
Precise spark advance control strategy for both static and dynamic operating conditions.
Unique calibration strategy allows accurate control of fuel delivery under both acceleration and deceleration.
User selectable spark and fuel delivery strategy for abnormal engine operation conditions to minimize possibility of engine damage whilst still maintaining engine operation. (eg: - over heated or over boosted).
Comprehensive limp-home function with user selectable default settings that ensure engine operation can continue after sensor failure has occurred.
Full compensation of engine control parameters for engine operation at any altitude (fuel delivery, ignition timing and boost pressure).
Adaptive learning (with memory) to minimize the number of user setups required and to provide optimal control of air/fuel ratio, boost pressure and idle stability.
Rev limiter with a soft characteristic that uses a combination of fuel delivery and spark control.
Fuel pump safety shut-off. Pump stops 3 to 4 secs after the engine stops.
Unit is ultra light weight/compact yet has sufficient drive capacity for high power continuous duty supplications. (One unit OK all applications from motor cycle to large capacity twin turbo engines).
Optional interface unit to allow sequential operation without the need for separate crank/camshaft sensors or special multi-sensor distributor (P/N: - ADP102 available Q3-93).
Remote monitoring of all functions using optional telemetry adapter (available Q2-93).
INPUTS
Sensors
Ignition input Hall effect. (Also available for direct connection to magnetic reluctor type pick-ups).
No. 1 cylinder reference. (Also available for direct connection to magnetic reluctor type pick-ups).
Barometric pressure (internal to ECU).
Manifold pressure (internal to ECU).
Throttle position.
Intake air temperature.
Engine coolant temperature.
Exhaust oxygen (or optional Wide Range Air/Fuel Ration Sensor).
Adjustments
Idle mixture trim. (Internal to ECU and screwdriver adjustable from outside).
OUTPUTS
Main
8 off injector driver (optional 2 injectors per driver).
Ignition output
Open collector output to any of the following:
Single coil high-energy ignitions: Bosch 7 pin, Mitsubishi 3 pin.
Autronic Capacitor Discharge Ignition.
MSD 6A etc.
4 outputs are available allowing multi coil distributor-less ignition for application on engines up to 8 cylinders.
Auxiliary
Fuel pump/injector fuel shut off safety relay.
Multi function on-off or pulse width modulation output for either:
Engine cooling fan relay.
Idle speed actuator (variable duty cycle single pole type eg:- Bosch
Turbo charger waste gate control valve (SEM, most OEM types or AUTRONIC low or high capacity).
Turbo charger auxiliary butterfly control motor.
General-purpose duty cycle output with user defined characteristics.
Fuel used pulse output (for trip computer function).
SERIAL I/O
Communication with IBM compatible computer for calibration, fault diagnosis. (Some markets require special adapter).
MICROCOMPUTER
16 bit running @ 16MHz
SUPPLY VOLTAGE
Normal operation
Safe Limits
6.2V to 23V DC continuous
+/-24V (5 mins)
+/-80V alternator load dump (0.5 sec)
+/-1000V inductive spike (10 sec)
CURRENT DRAIN
@ Engine Idle
@ Max Engine Load
<1 Amp
<16 Amp (less depending on injector type and number)
OPERATING TEMPERATURE RANGE
Min
Max
-40°C
+85°C
ENGINE CYLINDER NUMBER SETTINGS
Number of cylinders
1,2,3,4,5,6,7,8,10,12,14 and 16
ENGINE RPM RANGE
0 to 30,000 RPM
0 to 16,000 RPM
0 to 15,000 RPM
Engines up to 4 cylinders
Engines 5 to 8 cylinders
Engine 10 to 16 cylinders
INJECTION DURATION TIMING
Min
Max
Accuracy
Setting resolution
0.7 msec
30 msec
+/-<(10 sec+1%)
0.1% approx.
INJECTION TIMING
Range
Accuracy
Setting resolution
0 to 720° (crank angle)
+/-<(1.4° + 0.3 msec)
2.8°
IGNITION TIMING
Advance range
Accuracy
Setting resolutions
FUEL DELIVERY AND IGNITION MAPPING
No. load sites
No. RPM sites
16 (max)
32 (max)
Both load and RPM sites are freely selectable
SIZE AND WEIGHT
L* W* H*
157* 122* 35*
180* 128* 35 mm (overall, including mounts and connector)
0.5 kg
CONNECTORS
36 way ‘AMP’ water and dust proof socket
  • 2 months later...
