Allow me to make an E92 M3 vs GT-R comparison.
I bought one of the first E92 M3s and had it for 3 years before switching to an MY11 GT-R when they arrived early this year.
I enjoy modifying my cars and love driving, these cars were/are my "extra" cars so did not have to be daily drivers if I didn't want them to be.
I enjoy some track work and would describe myself as a relatively fast amateur track driver.
I am not interested in impressing other drivers with the look of my car, so street cred doesn't matter to me.
The M3:
- the engine is an absolutely screamer, keenly revving to 8300rpm and the noise is probably one of the most racey you will find, behind the obvious V12s and flat-plane Ferrari V8s
- the M3 will not accelerate unless you have planned in advance, you must be above 4000rpm to be in the nice flat 400Nm-odd torque area and you will be driving a 335 up to 6000rpm, with 150hp still to come in the last 2200-odd rpm
- the chassis is beautifully balanced and it is very easy to feel and transfer weight front to rear
- expect to need brake modifications if you are doing track days
- the M3 seemed to be hard on the front tyres on track and you will require aftermarket parts to achieve proper front camber
- for driving out in your local hills, in my opinion of course, the M3 is almost the perfect car, combining the sound and racecar-style power delivery and with 414hp it is just the right amount of power to put a smile on your dial for a few seconds before reaching naughty speeds, and the M-diff is great fun :)
- spent a day at Winton once we had fitted a 580hp G-Power supercharger and 1:40 was the best achieved on Cup+ tyres with the car clearly needing suspension and tyre work to go further
The GT-R:
- much stiffer suspension, certainly feels heavier
- sounds bland and always will
- definitely not as much fun on the road, if you want to keep your license
- honesly the only real enjoyment I can find in the GT-R on the street is the odd powerslide in an off-camber hairpin, I am just not game enough to do the license-losing speeds the GT-R needs to deliver enjoyment, oh and the odd LC on the rare occasion one is at the front of the que at lights before a 100 zone...
- on track however the GT-R makes complete sense, compared to the M3 the limits this car has are frankly unbelievable, for an amateur to lap a GT-R with midpipe around Barbagallo in 1:04 says a hell of a lot about the car
- the most annoying thing on track is the transmission oil temperature management which is necessary if you want to avoid expensive additional oil changes, it is the biggest limitation but I believe there are modifications to help this, brakes will suffer as well, I am still working on avoiding a soft pedal at the end of the day
- expect reasonably high running costs if you intend to keep your warranty while doing track work, I have spent around $7000 on it in parts and services since March with 5000km on the clock
Hope that helps.
It looks like bmw have figured out the benefits of turbo charging as almost everything in their line-up is turbo charged now.
The new TT V8 M5 is a screamer with a dsg as good as the R35. The 2014 M3 will appear to resolve many of the issues with the current M3.
Great times ahead for motoring enthusiasts.
The M3:
The GT-R:
Hope that helps.
That's a pretty good summary.
The reason i purchased the r35 was merely due to lap time capability (in a truely road rego'd car). There are so many other cars what are much more fun on the street, some for seriously less money.
Lots of interesting comments floating around. My big confusion is that in the past I have had street cars that were ideal track cars but I never honestly got to experience their true potential so now I questioning what purpose fits my next vehicle:
Camaro - sort of a big boaty cruise
M3 - a prestige with a bit of sport
GTR - -a track car that I'd drive on the street with the thought of one day tracking even though it may never happen
Porsche - probably an ideal 'poser' car
M5 V10 - a V10...maybe the only time I'd get to own such an engine
You can see my weird thoughts, but after owning a 32,33 and 2 34 GTR's, everyone expects a 35 to be my natural progression
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
