Hey guys im going for a retune on Monday but this time im getting 555cc nismo injectors and a z32 afm put in.
My previous tune made 246rwkw on 16psi but bleeds back to 15 with supporting mods:
RB25DET with standard internals
JPC Highflowed turbo
Walbro 255lph in tank fuel pump
3" exhaust with high flow cat
FMIC
Splitfire coilpacks
Power FC
My question is how much boost can a highflowed turbo handle? The previous owner had highflowed the turbo at JPC and apparently JPC told him that it can handle 400-450hp?? :blink:
Im hoping that 18psi can see me around the 260+rwkw?
Cheers
Levi
Edited by Levy
https://www.sau.com.au/forums/topic/385722-jpc-highflowed-turbo/
i know that if put more boost in it will shorten the life span of the turbo but i want to know what would be a safe psi as a daily. Im well aware of the risks involved but i just want to hear some oppinons, not smartass comments. if your gonna take the piss take it somewhere else or keep it to yourself :cheers:
Edited by Levy
yes i do, boost doesnt normally kill turbo's its more the shaft speed etc, its a highflowed steel wheeled turbo, so i would expect it to sit on 22psi comfortably,
depending on what you use your car for ie daily or circuit etc, tune your car to suit, daily i would run 19psi on high boost, but on the track maybe 14 to keep the engine happy
Mate there are so many variables. Comp wheel/turbine blades/size/material, quality of porting, bearings used, etc etc etc. Not all highflows are the same, so unless you tell us the exact specs of the turbo, it will be impossible to say exactly what it can do.
The best thing you can do, aside from contacting JPC about it, is to give it to your tuner and ask him to tune it to the turbos efficiency. They will be able to figure out.
Makes sense to me, just the answer i was looking for thanks man i appreciate it :thumbsup:
Dont know the specs, so i guess il leave it to the tuner
Cheers
