Hey mate,
Im in the middle of building a 25/30 at the moment and currently have the following.
S2 RB30 Block non turbo pistons with RB25DET Head (welded up VCT), 26 Cams
I have put a RB25 Cometic 1.3mm MHG with ARP RB25 Head Studs.
However, information i am seeing is rather mixed, some threads are saying *run an RB25 HG* and others are saying *the RB25 HG wont work, must run a 30 or 26*.
What is your experience?
also, do you by any chance know what style of balancer, idler pully and guide i should be running?
The block has been tapped.
Thanks
Cheers,
https://www.sau.com.au/forums/topic/385755-rb2530-build/
26 cams in the 25 head won't work unless they are re-profiled to suit the hydraulic lifters. Also cams and lifters wear together running 20 year old cams from 1 engine with worn lifters from another can end in tears.
Use a 26 or 30 head gasket
Use a balancer to suit you car / ps pump / alternator
All twin cam RBs use the same cam belt idler pullies. So just buy the belt that suits and 2 new idler / tensioners
And don't forget a new stud and bolt for them
https://www.sau.com.au/forums/topic/385755-rb2530-build/#findComment-6153403
this. rb25 head gasket will not work with a rb30 block. rb30 is the cheapest from nissan.
if you had just a 25 in your car before then use everything from the 25 (balancer, block fittings, oil cooler, oil and water pumps etc)
https://www.sau.com.au/forums/topic/385755-rb2530-build/#findComment-6153743
I partly disagree with this part,
both 25 & 26 base circles on the cams have the same flat surface, if the lifters have wear marks (top of lifters has a indented grove from the cam) then id suggest to replace them
but yeah older motors have radiused base circles and lifters radiused to match the cam lobes so you can't mix them up, or the solid lifters unless you want to reset the clearances
https://www.sau.com.au/forums/topic/385755-rb2530-build/#findComment-6154240
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
