Ok guys, I couldn't search to see if this has been covered before or not since I was on my iPhone, but this blew my mind......
The rear seats on my c34 stagea are adjustable!!!!!!
Adjustable rear seats = mind blown.
Does anyone on here want to drive my car so I can sit in the rear seats?! :P
This just blew my mind!
That is all, now go on about your day as if nothing has happened....
https://www.sau.com.au/forums/topic/385757-stagea-rear-seats/
It's so amazing! It's standard on the c34 as well, but I didn't find out till today. After owning the car for 2 years! I sat in the back and I felt like a butt raped squirrell sitting that straight. So I pulled the lever while sitting and it went back! Boy was I amazed!
well since i got my tire changed yesterday and the dicks there threaded my bolts, my rim decided to say goodbye to my car and rolled away while driving....... so now i dont have rims on the rear. but i get to sit down in my awesome rear seats!
so its all good.
so its all good.
Hang on; you lost a wheel?
Any damage? I'm assuming they're paying to repair?
lost a wheel, but since i was running spacers, which they clearly saw. (as the r34 gtt rims wont clear my suspension due to such a shitty offset)
they threaded the nuts, and 3 of my bolts. so when i was driving the rest kind of undid themselves during my 3 hr drive, and when i hit 70kmh, i heard a rattle then my center cap with all 5 bolts flew out, and my rim incl tire followed........
luckily since i sacked my car and the rim was in the arches, it never fully dislodged, and just hung on by about 1-2mm on the bolts, giving me just enough time to pull over.
i then called them they came down and told me they didnt want to cover me because i had spacers on...... so the guy saw my shredded tire and told me he will be a good fellow and give me a new tyre the next day........ for the low fee of $50... i bought the tire brand new for $85!!!
so i will go there on monday and really turn his neck 180 degrees!
So note to self, never ever go to St George Tires.
Tyre shops and Rattle guns... They never mix.
I specify upfront; that if they use one to tighten the nuts, I will refuse to pay. I make them list it on their work order. I also make them list that there is no damage to the rims; particularly around the wheel nuts. I didn't pay $600 for 2pak paint; only to have some donkey destroy them.
Sounds like you were pretty lucky then; could've been much worse.confused.gif
  • 2 years later...
I thought they were adjuatable. Drove mine to adel from melb on wednesday night after pocking ot up amd remember they looked noce and layed back. Got home and showed the missus around it and pulled the seat down lever. When I pulled the seats back up they looked really straight. Looked everywhere for a button or lever then just resigned it to a lack of sleep. After reading this post, I had another look.. AHHH! There's the lever! Nice amd reclined! Man the japs are on to a lot of things awesome! Love my new stag
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
